Transmission & Drivetrain Gearboxes, Differentials, Clutches
Transmission problem
Old Apr 24, 2012 | 02:38 PM
GumbyEg's Avatar
Default Transmission problem
So the other day i was pulling away from a stop sign in my civic and it seamed to pop outta gear while i was pulling away, so i ended up coming to a stop. I played with it and it seams go into all 5 gears and reverse just fine but the car doesnt go anywhere. the speedo works aswell but it just revs up. also it goes into gear without the clutch no problem. my first thought was my axel may have popped out. so i replaced my axel(witch was bad to begin with) and still no luck. i have it on the lift at my work and i can put it into gear and the wheels will spin freely with the car in gear. at this point im thinking i may have blown the diff? any thoughts? any and all help will be greatly appreciated Thanks (oh and by the way i drive a 94 civic si)
Old Apr 24, 2012 | 07:38 PM
MR.johnson's Avatar
Default Re: Transmission problem
were you pulling away or launching the **** out of it lol?
if the speedo goes up the diff is still spinning... check the other axle, even if it looks like its fine i might be broke in the boot.
Old Apr 25, 2012 | 03:16 AM
GumbyEg's Avatar
Even though both wheels are spinning freely while the car is still in gear, it could still be the other axle?
Old Apr 25, 2012 | 04:01 AM
MR.johnson's Avatar
with an open diff yes.
Old Apr 25, 2012 | 04:57 AM
GumbyEg's Avatar
i was under the impression that the si tranny had lsd, no?
Old Apr 25, 2012 | 06:24 AM
MR.johnson's Avatar
Very few jdm d15b trans came with LSD but no us sohc trans did.
Ali F. Ahmad
Honda Civic (2006 - 2015)
Aug 6, 2017 01:50 AM
migueldiaz
Jul 30, 2011 04:41 PM
eg93LS
Aug 27, 2008 12:18 AM
integraboi1010
Mar 5, 2007 09:14 AM
T3T495GSR
Jan 14, 2006 07:38 AM
