Alternator tensioner bracket?
Old Apr 23, 2012 | 11:41 AM
bseballkid1990's Avatar
Default Alternator tensioner bracket?
I was installing my new alternator on my 1993 prelude and i kept tightening the bolt on the right until it wouldn't tighten anymore and i found shavings of metal so im pretty sure i stripped it. its the little bracket that sits under the alternator with 2 bolts and i can't find it anywhere can someone please help? the belt isnt tight enough and wont turn the alternator.
Old Apr 23, 2012 | 01:33 PM
Hawkze_2.3's Avatar
Default Re: Alternator tensioner bracket?
Remove the alternator and bracket and see if you did strip it... If you did, just get a new bracket.
Old Apr 23, 2012 | 03:08 PM
minilogoguy18's Avatar
Just go to the dealer and get a new one, it shouldn't cost much, might wanna get the long bolt as well. If you were local I have one at work in my tool box that's been there for years.
Old Apr 23, 2012 | 04:24 PM
Gamble_wrx's Avatar
what they said. your looking at maybe 20 bucks. if you want i might have one laying around. ill look tommorrow.
Old Apr 23, 2012 | 09:23 PM
I know it's the bracket because it was hard to turn in (still loose on the belt though) and all of a sudden it got easier and i noticed the shavings and that the tension didnt get any tighter the more i turned. I'd be willing to pay for one and shipping if it's reasonable. Thanks for the help guys! I went on napa, autozone, and advanced and none of them had it.
Old Apr 23, 2012 | 09:40 PM
Wing8806's Avatar
Is this just the adjustment bolt on the end of the alternator bracket? As in the long 10mm bolt on the alternator that is towards the bottom/front with a second 10mm bolt on the actual bracket - or the 12mm bolt+nut that's directly under the alternator?
(assuming it's mounted the same as a 5th gen's)
and what model is your 4g? (so i can help search)
Old Apr 24, 2012 | 02:53 AM
Why are you going to aftermarket auto stores? I already said you have to get it from the dealer.
Old Apr 26, 2012 | 07:51 AM
patroick67's Avatar
Yeah I manage an advance auto go to a Honda dealer no one else will have it!
Old Apr 26, 2012 | 09:15 AM
brittpeggy13's Avatar
yes going near the dealer is the best do not waste you time.
Old Apr 27, 2012 | 08:47 PM
I went there even before my first post... and I was hoping I could get it off one of ya'll so I can get my car back on the road.
chazor
Jun 26, 2016 09:58 AM
ca-rs
Jun 16, 2010 12:50 PM
Park
Dec 19, 2004 03:09 PM
