HELP. Winshield washer nozzles don't spray
Anyone know why the windshield washer nozzles on my civic hb don't spray
fluid?
Could there be a blown fuse somewhere that I may need to replace or what?
What can i start checking for?
Any help in this matter would appreciated.
fluid?
Try and listen to them..you should hear a motor. If you do, they are most likely clogged. Get a pin and just stick it in the holes.
If there is not sound from a motor, you prolly blew a fuse or something.
Do you have the LED ones? j/k....haha..
Anyways, is it leaking anywhere? but as fowler said, listen to it and see if theres a motor working. If there is, the lines probably have a problem. If it doesn't, check the relay and work from there.
anyway check the hose for it on the shock tower (driverside) and unplug it. try squirting, if it does then u know its the squirters on the hood. if not then the motor for it is on the reservoir behind the bumper. check that. i have an extra one if u want.
krazy
mYsTeR2
10
Dec 14, 2003 11:10 AM
