Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2004 accord w/ac problem help
Old Apr 21, 2012 | 08:41 PM
ejfromwestbay's Avatar
Default 2004 accord w/ac problem help
clutch does not engage where do i start
Old Apr 21, 2012 | 08:50 PM
slyda24's Avatar
Default Re: 2004 accord w/ac problem help
First check the fuse and connections to the clutch, your refrigerant may also be low causing the clutch to not engage. Also check to see that the low cut out (pressure) switch is in good working order.
Old Apr 23, 2012 | 04:35 PM
Thank you for your reply how do I check that low cut out (pressure)switch.
Old Apr 23, 2012 | 07:22 PM
thank you it was the connections
dannydarkman
May 27, 2018 06:27 AM
Roadblock27896
Jul 24, 2009 08:41 PM
sk8er602
May 22, 2007 07:25 PM
dlbshonda
Aug 4, 2004 06:42 PM
