2004 accord w/ac problem help
Re: 2004 accord w/ac problem help
First check the fuse and connections to the clutch, your refrigerant may also be low causing the clutch to not engage. Also check to see that the low cut out (pressure) switch is in good working order.
Thank you for your reply how do I check that low cut out (pressure)switch.
dannydarkman
05-27-2018 06:27 AM
dlbshonda
08-04-2004 06:42 PM
