2007 Honda Accord 4 cyclinder AC Clutch not Engaging
Hi, I have a 2007 Honda Accord 4cyclinder 4 door. I replaced the relay and the clutch does not want to engage. It does however engage when I jump it. As well, my blower motor resistor sent bad so I jumped that temporarily so it’s only blowing max air. Would that effect the clutch not to engage. The freon level is good, but when I jump the relay for the clutch to engage, I’m not getting very cold air. Any suggestions would be much appreciated! Thanks!
Re: 2007 Honda Accord 4 cyclinder AC Clutch not Engaging
I'm having the exact same problem. Relays and fuses are good but clutch won't engage. If you don't mind me asking, which wire did you jump to check if the clutch would engage. I only see 2 black wires going to the compressor.
It was the relay for mine. I switched out the rad fan relay to test it and the clutch engaged. I got a new relay and mine is working again. Thanks
I verified by engaging the compression clutch mentioned above and turned the car on. I was getting cold air. From talking to a mechanic buddy of mine, it looks like it could be the module not sending the signal.
oranginal
06-16-2007 07:39 PM
