93 accord trans prob any help appreciated
i have a 93 accord my trans runs good for a minute or so the stops running until i turn the car off then back on then it does it again over and over does any one know a solution?
Re: 93 accord trans prob any help appreciated
Are you getting starter crank but no ignition? If so, it could be a Crankshaft Position Sensor going out. It will cut off fuel to your engine of it is faulty and does not correctly sense the crankshaft. DOn't know if a '93 Accord even has them but I had the same sort of issue on my vehicle and that was the problem. Replaced the CPS and now no issues.
idreamHonda
01-20-2006 11:30 AM
