Replaced the oil seal on distributor and now engine won't start
i replaced the oil seal on my distributor and now i cant get the car to start, it cranks over like it wants to but doesn't pop off.
I already checked for spark and it was good, its got a good battery, and is getting plenty of fuel. the plug wires are in the right order also.
not sure what is causing this any help is greatly appreciated
d16z engine. I've tried everything I can think of and even tried tdc, still won't start, do the magnets need to be a certain gap from the propeler on the shaft.
did you check the tdc is corrrect and your not at bdc
alot of people make this mistake
thats why it wil be 180Deg out
pull the valve cover put crank at tdc check valves are both loose on piston 1
also check the timing mark on the cam gear
then check your dizzy
jonnybadboi9
Mar 14, 2007 06:17 PM
javiergt02
15
Aug 21, 2006 07:37 PM
AmginE
Feb 27, 2004 02:17 PM
halim
Jun 9, 2002 07:50 PM
