Check Engine Light
Hey wassup i have a 91 ef and my check engine light is on.. i read the code on the ecu and it blinks 6 times. ever since the light came on my gas milage has been sucking. i know in theowners manual says 6 blinks is temperature gauge and something else i cant remember but i tried reseting the ecu by disconnecting my battery for like 20 minutes but its still there. my book says take car t dealership but nahhh.. so what could it be or what can i do ? thanks
code 6 is for the temperature sensor (TW) for the ECU, not the gauge - gauge sensor doesn't give a CEL and a code - TW sensor affects injector timing and duration, ignition timing, idle control, etc. - TW sensor is located on the end of the head below the distributor - has a 2-wire connector with red/white and green/white wires - either the sensor is bad or you have a problem with the wires or connector
@ kayita first make sure the ecu cover isint put on backwards. i thought mine didnt work either but then i took the cover off and discovered that the previous owner had taken the cover off and accidentally put the cover back on facing the wrong way. check that first cuz it happend to me lol
jwisecup
Feb 18, 2013 11:23 PM
TcUiRvBiOc
May 26, 2007 03:41 PM
but my problem is finally solved! thanks to jlicrx
thank you so much dude
