Custom ITB HELP
Old Apr 12, 2012 | 12:08 PM
95accord3267's Avatar
Default Custom ITB HELP
How do i install the sensor thats usually overtop of the stock throttle body?
Old Apr 12, 2012 | 12:56 PM
scmil95eg's Avatar
Default Re: Custom ITB HELP
The MAP sensor?
Most will switch to TPS-based load with ITB's however if you want to run speed-density, you'll have to tie all four runners into a common vacuum block, then vac. block to MAP.
Old Apr 13, 2012 | 02:37 PM
okay thank you
Old Apr 17, 2012 | 02:56 AM
GearHeadDeals.com's Avatar
The common vacuum block is the common way to do it, like he had told you. I like that way better myself too.
DelSolMarine
Welding / Fabrication
Jun 28, 2011 11:37 PM
hybrid1990crx
Nov 1, 2010 07:03 AM
guy_from_nerk
Feb 18, 2008 01:26 AM
da9blk1
Oct 16, 2007 02:41 AM
01ITR#700
Apr 24, 2003 10:28 AM
