2001 Honda prelude sh doesn't want to go into reverse
Old Apr 11, 2012 | 10:23 PM
MTracing's Avatar
Default 2001 Honda prelude sh doesn't want to go into reverse
Hey guys, I just picked up a bb6 and it has a 98 yranny swapped into it. The old one is bad I assume. When I got it... It didn't really wanna go into reverse.... But it went in. Now it doesn't even wanna shift into reverse I push the clutch in all the way, my fluid is level. And I bleed my clutch system. But she still doesn't wanna go into reverse. What do I do next? What can I do to diagnose the problem.
Thanks ahead of time!
Old Apr 12, 2012 | 02:12 AM
arsalanshj's Avatar
Default Re: 2001 Honda prelude sh doesn't want to go into reverse
did u miss shift any gear if u miss shift reverse gear stacks
Old Apr 12, 2012 | 03:00 AM
minilogoguy18's Avatar
Idler gear fork may be bent, you could try rolling your foot off the clutch slowly while pushing the lever to reverse so that everything in the trans will rotate and make it easier for it to line up. Reverse is straight cut with no synchronizer, sometimes doesn't line up.
Old Apr 12, 2012 | 06:06 AM
MTracing's Avatar
Yes I mis shifted into 3rd two times I will try right now to let my foot of the clutch slowly. Thanks guys, I'll get back to you on that.
Old Apr 12, 2012 | 06:14 AM
MTracing's Avatar
It still doesn't want to go in. I bought the car with it being rough to go in and leave reverse. Then after I miss shifted.... It doesn't wanna go in now
But when I let go of the clutch slowly... It went in half or a quarter way into gear.
Old Apr 12, 2012 | 01:04 PM
chancefm's Avatar
I had an issue like this on my 98SH and it turned out my clutch disc was separating. Adjusting the clutch pedal gave me another 2-3 weeks before I had to drop the transmission and replace all that good stuff. Hope this helps...
Old Apr 12, 2012 | 01:45 PM
Drop the transmission and pull it apart, no other way to fix it.
Old Apr 12, 2012 | 03:58 PM
MTracing's Avatar
ok, well i also have the option of buying a h23 tranny for 250$ from a friend. so are you guys thinking its worth taking that one out and putting the h23 or fix the h22?? im just in highschool still and dont have the greatest funds out there. I swapped a a tranny in my civic before, so i know how it is done. But i have never taken one apart... and have no idea what is going on in there!
But is there a way to tell if it is the clutch disk separating... or the tranny is going out?
Old Apr 12, 2012 | 04:43 PM
TheJGB3's Avatar
You have to use an M2U4 SH trans, nothing else will fit without removing the ATTS and fabricating an axle bracket in it's place.
Synchro-tech sells remanufactured trannys for $1195 (includes the carbon synchros)
http://www.synchrotech-transmissions.com/
Old Apr 12, 2012 | 05:02 PM
MTracing's Avatar
Ok, so i would have to get the m2u4 tranny for it then. Perfect but is there a way to check if its tranny or clutch disk separation?
Old Apr 12, 2012 | 05:09 PM
If there was a problem with the clutch you'd be having problems with all the gears, ignore the post about the clutch.
Old Apr 12, 2012 | 05:25 PM
MTracing's Avatar
Ok. I guess that makes sense then. What are you guys thinking is messed up in there? Because I could try to tear it apart... If its nothing terrible!
Like is there a DIY for it? And manual that has this stuff in there?
Old Apr 12, 2012 | 05:32 PM
TheJGB3's Avatar
The only way to know is to remove the tranny and split the case open. You might as well put in a new clutch, pressure plate, TOB, and rear main seal too while it's apart and
FYI - Mitchell flat rate for rear main seal R&R in an SH is TEN HOURS (the ATTS has to be removed first). So if you're doing it yourself at home DOUBLE that and add a few more hrs.
Old Apr 12, 2012 | 06:56 PM
AngryAgent's Avatar
You're in luck. I have an SH tranny I will be selling here shortly. No grinds and ATTS works! Make me an offer. I can send you a video of the car driving if you like. Getting rid of my whole SH drivetrain and swapping to something better.
Old Apr 12, 2012 | 07:26 PM
chancefm's Avatar
If you plan on pulling all that apart yourself you should invest in a slide hammer with an extension and the tool that threads onto it for pulling CV axles. That will make life a lot easier and anyone that says different is lying to you.
Old Apr 12, 2012 | 07:31 PM
chancefm's Avatar
What are your plans for the motor? I am looking for some parts...
Old Apr 16, 2012 | 10:16 PM
MTracing's Avatar
i talked to a buddy of mine, and he had stated that it might be the shift linkage! so i checked it out, and i cant tell anything from the shift linkage. I was wondering is there like a way to tighten or loosen the shift linkage?? anything that i can do?
Old Apr 17, 2012 | 05:43 PM
godslayer's Avatar
I've got about 25,000 miles on my Synchrotech tranny and so far, so good. I also had them throw in a mechanical LSD when I ordered. It was an additional $600 but they did the install for "free" and guaranteed proper shimming and installation.
I had to get a new tranny because mine did the same thing yours is. It started with reverse going and then went to also completely losing fifth gear. I wish I would have had the time to break in to the transmission myself and do some hands-on learning but I just couldn't afford the down time.
Old Apr 17, 2012 | 05:50 PM
godslayer's Avatar
Like the clutch, wouldn't a non-functioning shift linkage cause you issues in EVERY gear?
nocturnal_sol
Mar 25, 2008 04:29 PM
jaydem7
12
Sep 2, 2007 05:12 PM
jli18
Nov 5, 2006 09:12 PM
Blk_Lude98
Dec 27, 2004 09:42 PM
4thgenlude
Oct 5, 2004 09:30 PM
