Key stuck in ignition
Old Apr 10, 2012 | 04:56 PM
Rusty_hoock's Avatar
Default Key stuck in ignition
So I have a stock 91 Accord and the key is stuck in the ignition what can be done to get it out? Also will the tumbler still work? Or do I need a whole new ignition?
Old Apr 10, 2012 | 04:58 PM
CRX Si69's Avatar
Default Re: Key stuck in ignition
Is it broken off in there, or is the key still fully intact?
Old Apr 10, 2012 | 05:05 PM
Its still in there just wont turn all the way back so I can take it out. I tried jiggling the key and stering wheel at the same time with no luck.
Old Apr 10, 2012 | 05:22 PM
bakerskater11's Avatar
Is the key bent? Because my key sometimes gets stuck as well because it's bent, usually after unlocking my rear seats due to the lock being a little stiff. Usually i can bend it a bit and get it out, but i'm sure you've tried gettin out a bunch of different ways..haha
Old Apr 10, 2012 | 05:24 PM
Ill have to take a look i dont think its bent.....
Old Apr 10, 2012 | 08:00 PM
75aces's Avatar
The last time it happened to me I turned to on and off a few times. Cycle key off on position a few times and try pulling out while turning in off position. Its more than likely worn down teeth. Get new key made. As long as the key does not break in the ignition, the cylinder should be fine.
Old Apr 11, 2012 | 04:35 PM
AccidentproWn's Avatar
Automatic or manual? The auto has a key lock out feature so you can only take the key out while in Park. If it's auto try jiggling the shifter while turning the key. It could also be a problem with the electrical parts in the shifter.
(Borrowed this picture from the Accordingly Done forums.)
Connecting F and I allows the key to be removed.
Old Apr 12, 2012 | 10:00 AM
dailydrivencd5's Avatar
Bump for the diagram!
Old Apr 12, 2012 | 12:16 PM
Just FYI the shifter wasn't all the way engaged lulz thanks for the help
Old Apr 12, 2012 | 08:26 PM
That might help bro, haha. Good stuff
Noch
May 31, 2010 05:16 AM
jaydem7
Mar 7, 2008 06:50 PM
dc2go
May 23, 2005 10:33 AM
qcktegls
Jan 9, 2005 03:52 PM
Briman2021
Feb 3, 2004 12:03 PM
