Key won't go into ignition - Honda-Tech - Honda Forum Discussion
Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 USA Accord and Inspire
Old 05-30-2010, 02:43 PM   #1
Noch's Avatar
Default Key won't go into ignition
I have an 03 Accord coupe that won't take the key. Sometimes when wiggling for 30+ mins it would work but now the key won't go in at all. It's one of those laser cut keys so I can't simply go to a local hardware store to make a new one. I've heard a few things ppl have told me to try such as WD40 the ignition (not sure how safe that is). The key only goes in a few cm and the ign. beep does go off but the key doesn't go in all the way and if I leave it in there it gets extremely warm. I've also been told that it's possible the key is worn down to the point of not being recognized by the car. Other symptoms that have come up that I believe may be related is that now the steering wheel is locked at a 45 degree and the brake pedal is very stiff. I've looked for hours and hours for help but have found nothing that can solve this. So should I be looking at the Key or Ignition? Any troubleshooting ideas? I really don't have the money to take it into Honda and we all know that charge a ridiculous amount. Someone please help.
Noch is offline   Reply With Quote
Old 05-31-2010, 05:16 AM   #2
My Name is Nobody
MSchu's Avatar
Default Re: Key won't go into ignition
You can try wiggling the steering wheel left and right as you try and turn the key to the on position... but that really will not help you i you can not get the key all the way into the ignition.
I would have to say that from your description, it sounds like you are going to have to replace the ignition with a new set up. does your key work well in the door and/or trunk or is it stiff?
MSchu is offline   Reply With Quote
Key won't turn in ignition ? opinions please? crxaddikt Honda Accord & Crosstour (2003 - 2012) 1 07-03-2016 12:08 AM
Need a new key 00honda Honda Accord & Crosstour (2003 - 2012) 5 02-24-2014 10:30 AM
Key won't turn in igntion minguswooten Honda Civic (2001 - 2005) 6 05-04-2013 08:08 PM
Ignition won't lock steering wheel Si EM1 mark11017 Honda Civic / Del Sol (1992 - 2000) 5 04-02-2011 06:23 AM
Factory Key Gone Bad? :jdmshmaydm: Acura Integra 3 07-11-2003 02:02 AM
Tags
2003, accord, civic, enter, fit, honda, ignition, key, odyssey, prelude, problems, recognized, tech, turn, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
