B16 in Del Sol Runs Rough
Old Apr 4, 2012 | 04:51 PM
94_DC's Avatar
Default B16 in Del Sol Runs Rough
B16a2 with rebuilt head. Car starts but runs rough and keeps idle at 1k, dosen't rev past 3k and bogs/anti lags at that point.
Brand new plugs fouled. No CEL's, Checked mechanical and Ignition timing. Adjusted Valves, changed dizzy and ECU. New plugs and Wires. Compression tested at 210 across. Grounds cleaned, injector wires re checked. Map sensor and TPS checked as well.
Don't know what else it could be, would like to take suggestions.
Old Apr 4, 2012 | 08:22 PM
habanerored06si's Avatar
Default Re: B16 in Del Sol Runs Rough
What's the status on your tune? Correct Engine Mangement?
Old Apr 4, 2012 | 09:43 PM
Saleem786's Avatar
Plug wires in correct order? Sounds like the symptoms for wrong firing order..
Old Apr 5, 2012 | 06:15 AM
motegicivic's Avatar
Plugs fouled how, carbon, oil, running lean?
Old Apr 5, 2012 | 06:27 AM
Red_Army's Avatar
sounds like your in limp mode. you sure you have no CELs and the CEL bulb works?
my b16 did this when i forgot to hook up engine temperature.
Old Apr 5, 2012 | 07:25 AM
94_DC's Avatar
just a b16 map from a reputable local tuner. pulled off battery cables for a few hours to make sure not in limp mode. checked for codes even no cel. correct firing order. Plugs seemed fouled from fuel or at least smelled a bit gassy. They were black as night. Double checked all wiring with my other car all seem to be in correct places.
Old Apr 5, 2012 | 07:30 AM
Are you running a cat?
Old Apr 5, 2012 | 07:36 AM
94_DC's Avatar
open header at moment.
Old Apr 5, 2012 | 04:56 PM
94_DC's Avatar
Any other suggestions?
Old Apr 9, 2012 | 08:02 AM
94_DC's Avatar
bump anyone else have this issue before
Old Apr 10, 2012 | 04:39 PM
94_DC's Avatar
What would cause a car to use too much fuel?
Old Apr 15, 2012 | 10:56 PM
94_DC's Avatar
bump still not working right.
Old Apr 16, 2012 | 01:26 AM
HondaPartsHero's Avatar
Technical Hero
Sorry to beat a dead horse but does the check engine light stay solid when you jump it to check the codes
Old Apr 17, 2012 | 01:28 PM
94_DC's Avatar
Nope, no flash or solid.
DelCarajo
11
Nov 12, 2010 12:11 PM
Engage
20
Mar 29, 2009 07:49 PM
gringo7718
Dec 20, 2008 09:06 AM
vlc92189
Mar 3, 2008 01:41 PM
SIR2DelSol
Jun 15, 2005 09:59 AM
