Need help for cams : skunk2 stage 3 or pro's 1 for my setup
I got a stock 1999 b20b block stock with a build
B16 head super tech valvetrain & 3 angle valve job with a skunk 2 mani 68tb mm , should I go with pro 1's or tunner 3's
Well, the reason that most people aren't responding to your thread is because you failed to mention what you are going to mainly use your car for, daily driven, track, etc.. Also, you failed to mention your goals. Are you looking for peek power or driveability?
These cams seem a too large for your compression. If it is a stock block B20, you aren't going to get as much as you would think out of either set of cams.
Try posting this in the "All Motor" section. You should get a bit more information over there.
I think one of the best deals out there right now is from Edelbrock. They have a stage 2 strip/street cam set on clearance for something like 77% off right now. I just ordered a set myself. They make very good product!!
I think the going price right now is $177
YoungMoneySi
Oct 16, 2007 08:56 PM
Combustion Contraption
16
Apr 5, 2004 02:17 PM
