Jun3 or Skunk2 cams
Old Jun 24, 2002 | 01:35 PM
Fooser's Avatar
Default Jun3 or Skunk2 cams
I cant decide what cams to buy. I'm going for either stage 2 or 3 cams with upgraded valvetrain.
My friend at a shop I go to all the time told me he can hook me up with skunk2's for $700.00.
Whats the average price for Jun3's? Also what type of valvetrain should I get with this setup? I would also like to know what type of prices to expect for the valvetrain.
Old Jun 24, 2002 | 02:58 PM
B00ST2nR's Avatar
Default Re: Jun3 or Skunk2 cams (Fooser)
Jun3's and Skunk2 Stage 2 are very similar. Skunk2 Stage 3 is Race only cams...
Old Jun 24, 2002 | 03:22 PM
Malice's Avatar
New User
JUN 3's go for about 900 bux. the stage 2's give similar results and is about 2 bills cheaper. I'd go with the skunk's
Old Jun 24, 2002 | 04:14 PM
BlackGSR's Avatar
Default Re: Jun3 or Skunk2 cams (MaliceGSR)
Yeah, Skunk2 made some pretty decent cams. Stage 1 and Stage 2 both make great power.
I'm starting like them ...
What CR do you have? Please don't tell me 10:1.
Old Jun 24, 2002 | 04:18 PM
TeamTooQuick's Avatar
Default Re: Jun3 or Skunk2 cams (BlackGSR)
if you want to go with the stage 2's or jun 3's i suggest you up your c/r. If you are going to stay with the stock c/r then go with the stage 1's. Just my .02 cents....
Old Jun 24, 2002 | 04:22 PM
B-series Assassin's Avatar
Just make sure whatever of the two cams you get, you get the valvetrain upgrade with it. Nothing worse than valve lift...well there are things probably worse but still you know .
Old Jun 24, 2002 | 04:25 PM
Oh, and I see on your info that you have AEM cam gears. You might want to ditch those and get a pair of Skunk2 or something, cause nothing is worse than your gears slipping....wait a minute .
[Modified by B-series Assassin, 1:26 AM 6/25/2002]
Old Jun 24, 2002 | 05:39 PM
B00ST2nR's Avatar
Default Re: Jun3 or Skunk2 cams (B-series Assassin)
Yea. Get Skunk2 cams and Skunk2 Cam Gears. Can't go Wrong with them...
Old Jun 24, 2002 | 06:35 PM
hYpE-R-29's Avatar
Default Re: Jun3 or Skunk2 cams (b18c1 dc2 R)
are stage 1 more safer than stage 2's..i know u need a valetrain upgrade for 2's...and how much difference in power are u looking at?..also wat about idle problems?
Old Jun 24, 2002 | 06:41 PM
Sh!+F@ce's Avatar
Anyone have a link to the JUN3 web site? I have done searches and can't seem to find it.
Old Jun 24, 2002 | 06:45 PM
B00ST2nR's Avatar
Default Re: Jun3 or Skunk2 cams (hYpE-R-29)
Skunk2 Stage 1's are better for dropping in. With Stage 2's you really need to Dyno Tune them or they won't run as well. Both will do better off after Dyno Tuning (obviously), but the Stage 2's need a valvetrain upgrade, whereas the Stage 1's are perfectly fine with your stock valvetrain (As long as you don't pass your 8200rpm redline).
Old Jun 24, 2002 | 06:46 PM
B00ST2nR's Avatar
oh yea.... Plus Skunk2 Stage 1's are CARB Legal.
Old Jun 24, 2002 | 07:19 PM
hYpE-R-29's Avatar
how much hp we looking at with the Stage 1's with a setuplike urs bro.
Old Jun 24, 2002 | 07:27 PM
B00ST2nR's Avatar
The Shop estimated around 180wHPish.
Old Jun 24, 2002 | 09:41 PM
knighteg's Avatar
how muchfor skunk 2 cam gears? how much of a difference do they make alone? and will the vafc help in tunning these? i have a 94 gsr, looking for a few extra ponies, i still need a header also. but would like to get adjustable cam gears first, but do they work well w/ out the actual cams or what?
thx, later
Old Jun 24, 2002 | 10:31 PM
Malice's Avatar
New User
Default Re: Jun3 or Skunk2 cams (knighteg)
cam gears should be one of the last things u want. u could get them now and have your car tuned. if u get the header later, then it'll have to be re-tuned
Old Jun 25, 2002 | 03:10 AM
LOwrestling2001's Avatar
kinda doubt its 180ish...StinkyTofu has 11.7 compression w toda Bs and only managed 180whp after tuning by Importbuilders. i'm thinkin along like 170-175 whp at most w/o raised compression.
Old Jun 25, 2002 | 06:26 AM
Fooser's Avatar
Default Re: Jun3 or Skunk2 cams (LOwrestling2001)
Well I have some AEM cam gears if anyone is interested. They have not been installed yet. Was planning it this weeked, but if I go with skunk2 cams I'm going to get the cam gears as well.
I think I picked them up for around $150
Seeing how I'm going to have to pull the head to do all this work I'm probably going to send it out to have the port and polish done.
Will a thinner head ghasket suffice for compression? or will I have to go into the bottom end and change out the pistons?
[Modified by Fooser, 3:27 PM 6/25/2002]
fastlittlecivic69
Jul 15, 2010 07:32 AM
Mr.Milton
Mar 29, 2008 06:01 PM
StuPid oNe
Jul 2, 2005 06:08 AM
tone*def
Jun 14, 2004 01:21 PM
Rembrant Q. Einstein
May 20, 2002 11:47 PM
