Swollen radiator hose 99 si
Old Apr 1, 2012 | 03:42 PM
93grayeg's Avatar
Default Swollen radiator hose 99 si
I went to change the oil in my 99 si today and I noticed the upper rad hose was swollen up pretty bad. I never had this happen. Car does not over heat , smoke , or loose and anti freeze. Does this just sound like a weak hose? Thanks guys
Old Apr 1, 2012 | 03:57 PM
MRGRIM's Avatar
R.I.P. Mark
Default Re: Swollen radiator hose 99 si
could just be old hose getting weak
what does it look like when cold
Old Apr 1, 2012 | 04:00 PM
Tony M.'s Avatar
Yeah man, I would just say it's an old hose getting weak. I have a 00 SI and my upper hose looked like it was going to bust. It was a pretty old hose that just needed a replacement.
Old Apr 1, 2012 | 04:14 PM
93grayeg's Avatar
i popped the rad cap and let the car cool down and it started to shrink back to normal
Thats what i was thinking as well
Old Apr 1, 2012 | 04:31 PM
MRGRIM's Avatar
R.I.P. Mark
get a replacement set
old rule replace the set or the rest die in sympathy
Old Apr 1, 2012 | 04:37 PM
civicjunkie17's Avatar
A swollen hose is 99% of the time just an old stretched out hose.
Old Apr 1, 2012 | 05:18 PM
Tkrizz's Avatar
There cheap to replace might as well just do that. Better than being stranded in the middle of no where worst case scenerio.
Old Apr 1, 2012 | 05:44 PM
furious94ls's Avatar
Yes, just get an OEM replacement.
Old Apr 2, 2012 | 08:39 AM
93grayeg's Avatar
I noticed today that car is not heating up as fast ? Is it possibly the thermostat causing a swelling? It seems like there is a lot of pressure in the system
Old Apr 2, 2012 | 09:45 AM
I'm assuming you have some of the original parts still on the car. It's safe to say you should change your t-stat, hoses, and if you haven't done so get the timing belt/waterpump service done as well.
Old Apr 2, 2012 | 10:11 AM
98civdx's Avatar
Master Detailer
Replace the T-stat while you are there. They are pretty cheap as well.
You will need to drain/bleed the system anyways, so it's not really any added work.
Old Apr 2, 2012 | 12:11 PM
DCRB's Avatar
when i buy a car part of the tune up i do is replace the t stat, any hoses that look/feel old, coolant flush, oil change, plugs/cap/rotor, trans flush, regardless of what the previous owner says is done to it.
Old Apr 2, 2012 | 05:46 PM
Get an OEM thermostat.
Old Apr 2, 2012 | 05:53 PM
andyz's Avatar
oil eats hoses, so look for any errant oil coming from valve cover or something
only hose I had to replace recently was one right underneath distributor...soaked in oil and swollen....
Old Apr 2, 2012 | 06:45 PM
98civdx's Avatar
Master Detailer
yes, do this!
Old Apr 2, 2012 | 07:11 PM
93grayeg's Avatar
I always use oem tstats. Aftermarket are junk . Replaced the hose today and everything seems fine
Old Apr 2, 2012 | 07:20 PM
98civdx's Avatar
Master Detailer
A autozone t stat bit me in the ***.
Old Apr 2, 2012 | 07:22 PM
Deetz's Avatar
Crazy Honda Guy
I think everybody covered things pretty good. I will only add that if you shop around/online you could even upgrade your hoses. I bought a 5 pc kit of silicone hoses for $70 shipped
Old Apr 2, 2012 | 07:27 PM
Arthas's Avatar
LOL mine is like this right now! Im just waiting for the day it gives out. Its swollen and mushy, my dizzy inner seal is leaking.
OP right now would be a good time to get some silicone hoses
Old Apr 4, 2012 | 12:49 PM
project ek4's Avatar
yeah just replace it before it tears...most def. an old hose
liquidx
Aug 21, 2010 10:02 AM
inthad
12
Jul 9, 2008 02:55 PM
huntarrr
Dec 14, 2006 03:51 PM
Cyber ITR
Jun 11, 2006 09:28 PM
bey
Jun 23, 2004 06:15 PM
