RPM's acting weird
Old Mar 31, 2012 | 03:50 PM
Kustom X's Avatar
Default RPM's acting weird
Hows everyone doing? I'm new here. And have a 96 civic with a weird rpm problem. I fixed the Idle fluctuating problem which was a bad intake manifold gasket but now I have another problem. When I tap the throttle in neutral the rpms go up then slowly drop to 1000 then rise up to about 1250 then back to idle at around 850.. Same thing kind of happens when im driving and push the clutch in and coast but when I'm coasting the rpm stay at 1500 then when i stop it does the weird idle thing.
Old Mar 31, 2012 | 04:16 PM
ehrkeith's Avatar
Default Re: RPM's acting weird
Dont think This is a problem my 04 civic dd dies this also as long as when the throttle is closed it idles properly you should be alright. And if it is worse than what's stated in your post make a vid that will help diagnosis.
Old Apr 1, 2012 | 10:42 AM
Kustom X's Avatar
it seems to run ok while idling. but not perfect. I would love to have it running smooth so I can start the body work. I was thinking it maybe the TP sensor, the throttle body, or even the throttle body gasket. I have another throttle body but need to buy a TP sensor for it and new gasket. just trying to save every dime possible so I can put it toward my paint.
Old Apr 1, 2012 | 03:31 PM
MRGRIM's Avatar
R.I.P. Mark
IACV is dirty clean it as it controls the idle
and will cause idle to climb up n down
Old Apr 1, 2012 | 05:26 PM
Kustom X's Avatar
I have 2 IACV's and cleaned both. It still does it with either one on.
Old Apr 1, 2012 | 05:43 PM
MRGRIM's Avatar
R.I.P. Mark
try carby cleaner and spray around vac points for leaks
Old Apr 1, 2012 | 09:34 PM
Kustom X's Avatar
I'm thinking there might be a small leak somewhere. But I sprayed throttle body cleaner all around. thats how I found the leak around the intake manifold gasket. I will try to make a video if that would help
Old Apr 3, 2012 | 07:21 PM
Kustom X's Avatar
Its got worst now. when I tap the throttle or sit at a stop light/Sign the the rpms will raise then slowly drop then go up and down between 1000-1300 3-10 time then settle at around 850. and when i Parked it at my house it did it for like 10 min. then it just went to idle. also it seems I have a slight tick around the intake manifold or injectors. Its sounds slightly louder then the tick from the injectors. my friend says it sounds like a loose lifter but wouldnt the noise come from around the valve cover
DO/\/\O
Jul 26, 2011 01:44 AM
d-it-big99
Oct 13, 2010 01:56 PM
NumberB
Jun 7, 2005 02:26 AM
CRX_Control
Nov 7, 2004 07:47 PM
PowderB16
Jul 16, 2004 08:34 PM
