running issues
just put a gsr motor in a teg and number two cylinder gets spark but the motor runs a little choppy and pulled number 2 spark plug wire off and didnt affect the motor could a injector be plugged up or does anyone have any other ideaS?
third and fourth only first was firing then got second firing then drove it and went back to only 3 and 4 firing and sounded like a valve hit and it idled wrong part throttle same wot same but its a high compression b18c1 block wiht a stock rebuilt b16 pr3 head
your observations are a bit confusing.
so you did a power balance and found cylinders 2 and 1 to be dead? am i reading that right? so you have spark to cyl 1 and 2? but no change when wires are removed?
check your compression as per procedure
compression is good it was about 215 across the board and first and second cylinder dont fire does not affect at all when you pull off the wire but it fired up and ran correct for about 10 mins then 1st and 2nd cylinder lost spark again
From: Pensacola, FL and every Court House in Louisiana
When I did my gsr swap the book I was using gave me the wrong firing order so I fired it up and it was only running on #1 cylinder. Sounded like hell
3,4 is the firing order of the distributor
1,2
1,2
