d16y8 swap wont stay started
Old Mar 28, 2012 | 03:53 PM
Ryan559's Avatar
Default d16y8 swap wont stay started
91 civic hb std dx 5spd transmission
89dx harness converted to mpfi with boomslang obd0-obd1 jumper harnes
d16y7 block,d16y8 head d15b7 distributer with ebay obd0-obd1 distributor adapters,
I just finished the swap and went to start it and it turns over and then dies right away. If i give it gas it stays started and runs normal if im holding the gas steady.
none of my o2 sensors are hooked up right now so i have codes 1,41
Also getting codes 14,and 30 iac and i think a/t signal? which dosnt make sense.
I think my harness is screwed up and my iac plug dosnt work because i got that code on my old motor too
im lost any help would be appreciated
Old Mar 28, 2012 | 05:50 PM
Ryan559's Avatar
Default Re: d16y8 swap wont stay started
Also just messed with the timing. If i turn the distributor(with the bolts loose) towards the back of the car it starts and runs a lil bit longer if i turn if toward the front of the car it stalls right away.
I dont have a timing belt cover right now so its hard to time ive been using the mark on the timing belt pulley lining it up with the arrow on the block
Any suggestions on a better way to time it. i dont have time get a timing belt cover for it right now
Old Mar 29, 2012 | 12:48 PM
Ryan559's Avatar
bump
Old Mar 29, 2012 | 12:59 PM
TearSDMF89dx's Avatar
did you swap your tps wires around?
Old Mar 29, 2012 | 03:07 PM
Ryan559's Avatar
yeah. all the wiring is right im pretty sure
Old Mar 29, 2012 | 03:13 PM
Ryan559's Avatar
Old Mar 30, 2012 | 12:29 PM
Ryan559's Avatar
ttt, i have a feeling its something to do with my tps? im going to see if its in calibration once i get my hands on a volt meter
Old Mar 31, 2012 | 12:27 PM
Ryan559's Avatar
bump.. anyone? tps is fine
derek18105
Nov 19, 2009 07:52 PM
sobe
Feb 26, 2005 12:27 PM
uranazo
Nov 15, 2003 04:24 PM
89 CRX SI
Apr 18, 2003 12:14 AM
