97 civic speedo not working .. i did the research!
i ran into a bit or a problem i have a civic with an h22 swap in it.
recently i dropped the tranny and replaced the clutch flywheel pressure plate and trow out bearing while i was doing that i decided to paint the tranny. so i took off the speed sensor and the back up sensor and covered the rest up.
when i put the tranny back in and started the car i noticed that my car way vibrating more then normal. so i took it for a test drive and found that my speedo wasnt working. my rmps are working fine just the speedo is not working.
when i try to rev the car past 4k it will die like someone just cuts the fuel to it. i think it is stuck on launch control.
i have replaced the vss already and still nothing i also checked the wiring for the speed sensor and they are all good.
i dont think that i could be my speedometer because it was working just fine when before and i haven't started the car scene. any help?
1997, 97, civic, fuel, fuse, honda, problem, problems, speed, speedo, speedodometer, speedometer, speedometers, stopped, working
