93 del sol gsr swap - code 14 and idle problems
Old Mar 26, 2012 | 08:38 PM
hasty91ef's Avatar
Default 93 del sol gsr swap - code 14 and idle problems
Ok I just rebuilt the gsr before swapping it in. Now im having idle issues. its idling at 1500 most of the time and other times when you start it up it will rev really high. not sure how to fix it. its throwing code 14. i know it the idle control valve and tried swapping with two others i have around the house and same thing. This is what ive done to the motor 11.4 to 1 pistons, port and polished,3 angle valve job, stage 1 cams, intake manifold, and 68mm t-body. I have a chipped p06 computer. I've already checked the firing order, and the compression. both are good. any ideas would be help me out
Old Mar 26, 2012 | 08:46 PM
jbpnoman's Avatar
Default Re: 93 del sol gsr swap problems
Go through everything and look for vacuum leaks. They can also cause a high idle and code 14.
Old Mar 26, 2012 | 09:26 PM
Former User's Avatar
Default Re: 93 del sol gsr swap - code 14 and idle problems
Does your engine have an FITV?
Old Mar 27, 2012 | 08:50 AM
hasty91ef's Avatar
no I don't have a FITV on the car. the t-body didnt come with one and my motor didn't come with a t-body. do I need to get one?
B16a2Em1
Aug 28, 2011 09:45 PM
revzx2
Feb 26, 2009 09:23 PM
97grnrs
Dec 2, 2005 07:02 PM
Glocked1
12
Jan 22, 2004 08:13 PM
