96 EX P0505 CODE AFTER WASHING ENGINE BAY?
Hello all,
I just recently cleared my P0138 code, which seemed to be my o2 sensor.
I reset the ecu, and my check engine light came back on after 40 miles.
I went to autozone thinking it was the same P0138 code, but instead I got a P0505 code.
P0505 meaning:
1. Vacuum leak
2. Dirty throttle body
3. iac motor defective
4. poor electrical connection to the IAC valve
What should I do? My car started to idle funny while I was out, but seems that the idle went away.
Should I reset the ecu and see if it comes back (one of those one time only codes?)
ALSO, I pressure washed my engine bay yesterday, but I bagged off most of the stuff.
P0505 meaning:
1. Vacuum leak
light hasnt come back on yet, but my cars idle is fluctuating from liek 1000rpm to 1600rpm.
I cleaned my iacv, what should I do now?
I don't see any vacuum hoses disconnected..
I cleaned my IACV, installed it back properly and I think I bled it properly.
Car is idling fine now, no fluctuation at all.
I prob just got the connector wet when I washed my engine bay.
Could this just be the fix? I will drive my car more tonight and just make sure, but so far so good.
Rekkerslude
Engine Management and Tuning
Sep 21, 2017 10:33 AM
