Cams and mechanical timing ?
Old Mar 25, 2012 | 06:46 PM
Slacker93eg's Avatar
10 Year Member
Default Cams and mechanical timing ?
I'm in the process of putting my motor together, and I am going to swap out the cam gears. I'm kind of confused here, with cylinder 1 at TDC, both cams should be at 12 o clock am I right? Also, when trying to remove the cam gear bolts, It's just turning the cams in the head. How can I prevent this aside from jamming a screw driver through them? (same for tightening)
So:
Cylinder 1 TDC / Cams ^ at 12 o clock
This correct?
Old Mar 26, 2012 | 12:24 AM
mouab18c1's Avatar
Default Re: Cams and mechanical timing ?
Nope the UP arrows on the cam gears are just a refernece for which they should be facing. There are TDC marks on the cam gears as well. You should be able to see them.
Best way to take off the cam gears is with an air compressor.
To put them back on, put the cams back in the head and tighten the screws until the cams start to turn over. This way you don't scratch up the cams by holding them down with vise grips or what not.
Old Mar 26, 2012 | 03:12 AM
DirtyDA9's Avatar
On the actuall cam about 5 inches from the cam gears, there is pretty much a big nut cast into the cam, the wrench is a tad over a 1" so I hope you have one handy....
killacam661
Feb 11, 2010 09:07 PM
TurboJdmEF9
May 26, 2006 02:16 PM
MDintegra95
May 5, 2005 08:28 AM
DrewQ1
Mar 7, 2004 05:03 PM
Twigster311
Jul 5, 2003 09:17 AM
