removing cam gears from cams
Old Jul 4, 2003 | 02:59 PM
Twigster311's Avatar
Default removing cam gears from cams
we have no air tools. how can this be done? I dont want to put the cams in any sort of clamp.......
thanks.
(yes, the cams/gears have been taken off the head already)
Old Jul 4, 2003 | 03:22 PM
irev210's Avatar
Default Re: removing cam gears from cams (Twigster311)
thats a tough one
I used a wooden clamp, would is too soft to damage a cam
if you dont have a wooden clamp, take some wood and stick it inbetween a C clamp
Old Jul 5, 2003 | 12:08 AM
Default Re: removing cam gears from cams (irev210)
hmm, so that really is the only option. I was hoping there was some trick to it...hmm. thanks man.
Old Jul 5, 2003 | 12:41 AM
kanzenr91si's Avatar
there should be a hole in the cam under one of the caps. either the first or second from the pulley. jam an allen wrench or something in it and it will hold it still while you loosen the pulley. or if your a baller, snap on makes a tool thats perfect for this and lineing them up.
Old Jul 5, 2003 | 08:45 AM
b19coupe's Avatar
If the cams are LS cams, they have a 27mm hex cast into part of the shaft, you can hold the cams there.
Old Jul 5, 2003 | 09:17 AM
Dokta's Avatar
Default Re: removing cam gears from cams (b19coupe)
i just had a friend grab hold of the cam gear with a rag and hold on tight while I loosened up the end bolt with a socket
Slacker93eg
Mar 26, 2012 03:12 AM
HFP_racing
11
May 12, 2009 06:12 PM
TurboJdmEF9
May 26, 2006 02:16 PM
DrewQ1
Mar 7, 2004 05:03 PM
