d16z6 t3t4 turbo ?
Old Mar 24, 2012 | 08:09 PM
thisguy2012's Avatar
Default d16z6 t3t4 turbo ?
ok so im looking in to getting a 94 civic d16z6 with a t3t4 turbo running a 8 psi
i know that a d16z6 should have a p28 computer but it says this 37820-p09-a00
does anyone know what it is and if i need to get a flashed p28 for turbo?
Old Mar 24, 2012 | 08:53 PM
JDM_teh_WIN!!'s Avatar
Default Re: d16z6 t3t4 turbo ?
P09-A00
Civic DX D15B7 SOHC
Old Mar 24, 2012 | 08:57 PM
Dc4LsTeG's Avatar
EK9
You need to have your ecu chipped. Then tuned when you go turbo. Lol at t3/t4 at 8psi
Old Mar 24, 2012 | 09:28 PM
well thats just what its at they say its not tuned so they run 8 psi but do i need to get a p28 computer or is it problay not a d16z6
Old Mar 24, 2012 | 09:50 PM
Dc4LsTeG's Avatar
EK9
It should already at least be chipped if its turbo. I wouldn't be buying someone's untuned turbo project though
Old Mar 25, 2012 | 05:40 AM
well i think it is chipped but the computer is wrong
it has two step on it in but someone set it at 3 grand so idk
im kinda new in to this honda world. real American muscle is bad *** but super expensive and im intrigued by these small engines making big numbers for the low
so what psi should that turbo be running at
Old Mar 25, 2012 | 06:11 AM
Dc4LsTeG's Avatar
EK9
Doesn't matter what ecu if its chipped.
Psi doesn't mean anything
Old Mar 25, 2012 | 07:17 AM
grumblemarc's Avatar
The Grumpiest
When an ECU is chipped it's just like wiping out Windows to install Linux. It doesn't matter.
Old Mar 25, 2012 | 07:28 AM
94EG8's Avatar
Seagull Management
I'm guess that actually said P06. You can chip and convert P06s to vtec. They use the same board as a P28 without the vtec components (which can be added) And yes once chipped it doesn't matter what it was orginally for. There's a few guys running toyotas and nissans on P06s using Honda distributors.
Old Mar 26, 2012 | 07:42 AM
no it defiantly says p09
Old Mar 26, 2012 | 09:52 AM
The Grumpiest
Originally Posted by BlueIntegraBoy
The P09 was a CX ECU that was superceded by the P05, according to Hondanet.
Old Mar 26, 2012 | 10:22 AM
OBD1 USDM P09-A00 Civic DX D15B7 SOHC
OBD1 USDM P06-A02 Civic DX D15B7 SOHC
OBD1 USDM P09-L00 Civic CX D15B8 SOHC
(same as P05)
OBD1 USDM P05-L01 Civic CX D15B7 SOHC
Miramax
Sep 16, 2015 01:26 AM
icehayden
Jun 21, 2007 10:16 AM
CivicLxFL
19
Feb 12, 2007 02:13 PM
