Attachment of nylon line and plastic t fitting
Old Mar 22, 2012 | 01:34 PM
98integrars's Avatar
Default Attachment of nylon line and plastic t fitting
I can't seem to get the nylon tube onto the t fitting haha, not sure if there's a certain way or not. I tried searching on google and on here alreaddddyyy...
Old Mar 23, 2012 | 04:07 AM
david974's Avatar
Default Re: Attachment of nylon line and plastic t fitting
you need a rubber fitting between the T and the nylon tube
normaly comes with gauge kit if it is one
Old Mar 23, 2012 | 08:57 AM
oh? where can i get one? I got the nylone tubing from a friend who got it from autometer,and i bought the t fitting at canadian tire, no rubber fittings were in the fitting box... got a pic of what you mean??
Old Mar 23, 2012 | 12:41 PM
kbouchard1092's Avatar
What are you Teeing into for? Boost gauge? What vacum line are you teeing into?
I wouldnt Tee into the FPR line...just get a vacum box.
You can use OEM vacum tubing and stick the nylon far enough into it to create a good seal
Old Mar 24, 2012 | 06:22 AM
so i should use the oem vacuum tubing overtop of the nylon tubing? It's a boost/vacuum gauge yes from autometer.
Was gonna t into the line everyone does haha
blackccoupe
May 18, 2004 07:26 PM
Civiclx
Mar 14, 2004 12:46 PM
Westsideboy
Apr 19, 2003 05:21 PM
Pengo
Jul 23, 2002 09:35 AM
greyzone
Nov 11, 2001 05:06 PM
