Attachment of nylon line and plastic t fitting
I can't seem to get the nylon tube onto the t fitting haha, not sure if there's a certain way or not. I tried searching on google and on here alreaddddyyy...
http://i273.photobucket.com/albums/j...9/IMG_0116.jpg |
Re: Attachment of nylon line and plastic t fitting
you need a rubber fitting between the T and the nylon tube
normaly comes with gauge kit if it is one |
oh? where can i get one? I got the nylone tubing from a friend who got it from autometer,and i bought the t fitting at canadian tire, no rubber fittings were in the fitting box... got a pic of what you mean??
What are you Teeing into for? Boost gauge? What vacum line are you teeing into?
I wouldnt Tee into the FPR line...just get a vacum box. You can use OEM vacum tubing and stick the nylon far enough into it to create a good seal |
so i should use the oem vacuum tubing overtop of the nylon tubing? It's a boost/vacuum gauge yes from autometer.
Was gonna t into the line everyone does haha |
