Autometer Boost Gauge question!
Old Apr 19, 2003 | 09:13 AM
Westsideboy's Avatar
Default Autometer Boost Gauge question!
Hey guys. I recently purchased a used Autometer boost gauge. Now, the vacuum line that is attached to the gauge is made of semi-solid plastic tubing and is fairly skinny. How do I attach this to a standard rubber style vacuum line under the hood? Is there some sort of adapter kit?
Thanks.
Old Apr 19, 2003 | 09:23 AM
krazyDOHC's Avatar
Default Re: Autometer Boost Gauge question! (Westsideboy)
when i was installing my friend's turbo... i accidently bent the line in half so i took his windshield wiper lines and used that as vacum line....no need for adapter, just find some rubber hoses that itll fit tightly in then tee it off to any vacuum source.
Old Apr 19, 2003 | 09:43 AM
Cruiser G's Avatar
You can go to the hardware store and get an adapter that goes from like regular size vacuum hose (don't know the exact size) to that boost line size tubing. That's what I did and it works great.
Old Apr 19, 2003 | 09:53 AM
Default Re: (Cruiser G)
Do you by chance have a picture of what it looks like so I have an idea of what I'm looking for?
Old Apr 19, 2003 | 10:11 AM
boostsohfast's Avatar
Default Re: (Westsideboy)
just go to pep-boys or a local parts place and buy some vacuum T's. It will provide an extra outlet from the vacuum line. DO NOT use windshield wiper lines as a vacuum line. You don't want to be able to pinch a vacuum line closed, it should be solid but still flexible.
Old Apr 19, 2003 | 10:14 AM
Daniel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Westsideboy &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys. I recently purchased a used Autometer boost gauge. Now, the vacuum line that is attached to the gauge is made of semi-solid plastic tubing and is fairly skinny. How do I attach this to a standard rubber style vacuum line under the hood? Is there some sort of adapter kit?
Thanks.</TD></TR></TABLE>
I stuck the plastic tubing inside of regular vacuum hose and then zip-tied the two together just secure enough so it doesn't come loose but not so tight that they got cinched together. works great.
Old Apr 19, 2003 | 10:15 AM
Default Re: (boostsohfast)
Yah, I know what the vacuum T's look like, but the thing is... on 2 ends of the T, will be where the regular vacuum line runs through...and then on the actually "T" end, is where I'd splice in the boost line...however the boost line is super duper skinny...? Do they make a T with an end that small? What I'm trying to figure out is if there's a special adapter made specifically for this application?
blufke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cruiser G &raquo;</TD></TR><TR><TD CLASS="quote">You can go to the hardware store and get an adapter that goes from like regular size vacuum hose (don't know the exact size) to that boost line size tubing. That's what I did and it works great. </TD></TR></TABLE>
saw that on a wrx site. bigger hose just slips over that brass fitting that sticks out of the back of the gauge and then you just transition to the smaller hose. supposed to make it a whole lot more responisive/accurate.
Old Apr 19, 2003 | 11:08 AM
Cruiser G's Avatar
This is what Im talking about. The boost guage I think comes with an adapter that the boost guage tubing goes in and there is a 1/2 pipe thread fitting out the other side. The threaded part screws into this piece from the hardware store. Does that make sense? It's kinda hard for me to explain.
Edit: The piece you need from the hardware store is basically a hose barb on one end, and female 1/2 pipe threads on the other.
Old Apr 19, 2003 | 03:54 PM
Okay...on the gauge that I bought, I'm missing the piece that the tube in that picture is connected to...the piece that'll allow me to screw it onto another fitting. Can I buy that brass piece from the hardware store also?
Mine's been cut, I guess...?
Old Apr 19, 2003 | 04:55 PM
inspyral's Avatar
I just used a 1/8 NPT hose barb and screwed it directly to my boost gauge. Then I just used regular vac line to tee into my FPR line.
Old Apr 19, 2003 | 05:21 PM
Cruiser G's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Westsideboy &raquo;</TD></TR><TR><TD CLASS="quote">Okay...on the gauge that I bought, I'm missing the piece that the tube in that picture is connected to...the piece that'll allow me to screw it onto another fitting. Can I buy that brass piece from the hardware store also?
Mine's been cut, I guess...?</TD></TR></TABLE>
Yea, Im pretty sure you can.
blackccoupe
May 18, 2004 07:26 PM
Civiclx
Mar 14, 2004 12:46 PM
Pengo
Jul 23, 2002 09:35 AM
Aeka GSR
Apr 5, 2002 09:50 AM
greyzone
Nov 11, 2001 05:06 PM
