Car wont start again
Old Mar 21, 2012 | 04:22 PM
brad22486's Avatar
Default Car wont start again
Pos wont start again 92 hatch w obd2 gsr swap used singe cam harness to get it started before pulled swap back out to put new seals in tranny put back in and now wont start main relay is making a buzzing noise and i tried 2 dif ones and both do the same thing its not getting spark or fuel i dont understand i pulled swap back out to make sure i didnt pinch any wires. Will it mess anything up if i pull motor when its still hot any suggestions will b appreciated i guess if i didnt have bad luck i wouldnt have any at all
Old Mar 21, 2012 | 04:28 PM
Dc4LsTeG's Avatar
EK9
Default Re: Car wont start again
Check engine grounds
Old Mar 21, 2012 | 04:37 PM
brad22486's Avatar
I did i sanded em down and everything
Old Mar 21, 2012 | 04:39 PM
Dc4LsTeG's Avatar
EK9
Any cels? Have a diff ecu you could try?
Old Mar 21, 2012 | 04:47 PM
brad22486's Avatar
Cant check cells car wont run and tried p72 and p28
Old Mar 21, 2012 | 04:52 PM
Dc4LsTeG's Avatar
EK9
You can check for cels without the car running
Old Mar 21, 2012 | 04:56 PM
brad22486's Avatar
Ill try
Old Mar 21, 2012 | 04:58 PM
brad22486's Avatar
I jumped it and check engine light didnt do anything but it is staying real dull
Old Mar 22, 2012 | 01:48 PM
brad22486's Avatar
Ok i spliced in 23 and 24 on conector a the pg grounds and ground them to the body now check engine light is bright but still wont start
Old Mar 22, 2012 | 01:54 PM
Dc4LsTeG's Avatar
EK9
Did you check to see if it throws a code when you ground the service connector
Old Mar 22, 2012 | 02:13 PM
brad22486's Avatar
Yes it just stays solid in the run position
Old Mar 22, 2012 | 02:26 PM
Jimster480's Avatar
you are missing your ground on your thermostat housing, either that or the tranny is grounded in the wrong place or your ground is not touching.
Old Mar 22, 2012 | 02:32 PM
brad22486's Avatar
Well i ran another ground from the thermostat to the body and it wouldnt start
Old Mar 22, 2012 | 04:01 PM
brad22486's Avatar
I traced the 4 ground wires from the thermostat to the ecu and spliced in and regrounded em inside the car and still nothing no spark or fuel
Old Mar 22, 2012 | 05:05 PM
Jimster480's Avatar
you said your relay is clicking? And it usually needs to be grounded on the motor. I had a friends car where they tried to ground the thermo ground on the chassis and it didnt work out.
Old Mar 22, 2012 | 05:23 PM
brad22486's Avatar
Well when i grounded the check engine light became brighter
Old Mar 22, 2012 | 05:26 PM
brad22486's Avatar
I ungrounded the 4 wires to the ecu and turn ign to run position and now main relay is buzzing
Old Mar 22, 2012 | 05:38 PM
brad22486's Avatar
Check engine light is also dim again
Old Mar 22, 2012 | 07:14 PM
brad22486's Avatar
Well i feel stupid as **** where i have my wires tucked the 2 plugs were mixed up so car runs now. But still cant get my wipers or horn to work
Old Mar 24, 2012 | 08:06 AM
Jimster480's Avatar
lol well check the grounds under the dash, and the fuses.
Old Mar 24, 2012 | 09:08 AM
grumblemarc's Avatar
The Grumpiest
Somebody should shoot you. You didn't think it important to mention right off the bat that you did a wire tuck? I bet you your wipers not working is also due to the shoddy tuck job.
BOOSTEDgreeneg
Sep 6, 2005 10:06 AM
JDMlyfestyle
22
Jan 9, 2004 10:36 AM
No More Civic
10
Aug 27, 2002 09:35 AM
CRzex
Nov 4, 2001 10:24 AM
