Help Car wont start????
New User
Help my car wont start!!! i checked all the fuses and everything checks out, when i try to start my car i can hear the starter clicking so its not that. i checked the ecu for codes and theres nothing but the check engine light is lit... any one have any clue to why my car wont start... btw its a 91 dx....
Re: Help Car wont start???? (CRzex)
Have you checked your main relay to see if it is functioning? Maybe your ignitor died like so many others. Check to see if you are getting spark and/or fuel. HTH.
cyber13
cyber13
If your light stays on with no codes check the following- there is a fuse in the dash fuse box labeled solenoid- be sure it is there and good. Also, check the ground that is close to the thermostat housing- remove and clean it and reinstall. If this doesn't help, with the key on, remove your sensor wires one at a time, checking the light each time. If the light goes out- inspect the sensor that let it go out when the connector was removed.
LScivic_wpg
05-27-2006 10:10 PM
No More Civic
10
08-27-2002 09:35 AM
