98' spec b18c type r - very low idle
Old Mar 20, 2012 | 05:07 PM
whoaitzbrain's Avatar
Default 98' spec b18c type r - very low idle
fixed
Old Mar 20, 2012 | 09:39 PM
crzycivic93's Avatar
Default Re: 98' spec b18c type r - very low idle
check wiring. start there.
if you can eliminate the ecu not being the issue.
Old Mar 20, 2012 | 09:41 PM
eg6 type-R's Avatar
try a different ecu
Old Mar 20, 2012 | 09:52 PM
EH2Kevin's Avatar
Do you have any other details?
Old Mar 27, 2012 | 09:40 AM
ok found the issue..had to re wire jumper harness. car is running good but idle is just a tad rough. idles fine with AC on but with AC off it boggs down to about 700 and is a little shaky.
Old Mar 27, 2012 | 09:43 AM
Leetfade's Avatar
Sounds like you just need to adjust your idle up a little bit. Should be an easy fix.
Old Mar 27, 2012 | 09:46 AM
on the freeway now lol my girl is driving. I will adjust the idle screw when i get home and update!
Old Mar 28, 2012 | 06:45 AM
fixed
808sAllMotorGSR
Jul 7, 2016 09:49 PM
Bhi Rds
May 8, 2016 06:19 PM
jdmchickx
Mar 26, 2012 06:50 PM
8VEYBEYB
Jun 7, 2010 09:18 AM
georgiajdm
Aug 11, 2009 06:31 PM
