MY CAR WONT START
Old Mar 17, 2012 | 12:44 PM
Cav3man's Avatar
Default MY CAR WONT START
Hey everyone im having some issues with my eg civic ex. So recently the distrubuter went out and i had to replace that so i replaced that got it all fixed and everything was fine. well then i lost my keys so i had to replace the ignition and i did that hooked everything back up right and now my car wont start. Ive tried everything to get it to start. It turns over "click click click" but wont officially turn all the way. ANYYYY IDEAS
Old Mar 17, 2012 | 12:46 PM
grumblemarc's Avatar
The Grumpiest
Default Re: MY CAR WONT START
Sounds like your wiring was faulty if it ran before you changed the ignition switch. Start tracing your work.
Old Mar 17, 2012 | 12:48 PM
Cav3man's Avatar
I made sure i did everything perfect. i double checked all my work when i did the ignition and everything was fine.
Old Mar 17, 2012 | 12:54 PM
The Grumpiest
Sorry. It doesn't sound like it. Worked before replacement. Does not work after. This one is not that hard to figure out. Did you use a wiring diagram? Does it start up if you push-start it? Battery dead?
Old Mar 17, 2012 | 01:16 PM
vitamin_c95's Avatar
I would check the battery charge first
Old Mar 18, 2012 | 12:11 PM
Cav3man's Avatar
I tried to charge my battery and didnt work, tried to jump it and it didnt work. Plus im getting power everywhere else. I went and backtracked my work with the ignition by pulling it apart and starting over and i still am having the same problem so i know its not the ignition
Old Mar 18, 2012 | 12:31 PM
ehrkeith's Avatar
Try doing a jump with the positive on the battery and the negative on the car body ground like the rad support, it really sounds like a dead battery.
Also i had this problem before, it turned out my Trans to frame rail ground was bad, take that off and sand all the connection points I'm pretty sure that will fix it. It was an off and on thing too sometimes it would work other times it would click.
if you need a pic let me know i think I got one around here somewhere describing it
Old Mar 21, 2012 | 06:52 PM
Cav3man's Avatar
car still wont start and its not my fuel
Old Mar 21, 2012 | 09:33 PM
UDRabbit's Avatar
Check your grounds Had a issue like this minus the ignition switch on an old Civic i had ended up being a bad ground connection right under the alternator! believe there is 4 total grounds thru. out the engine bay area make sure you got good connections!
post up if problem still is occuring.............
Old Mar 22, 2012 | 06:37 PM
Cav3man's Avatar
I read something about my ecu could have gotten an error code when i switched out the ignition??
Old Mar 22, 2012 | 09:01 PM
UDRabbit's Avatar
that is poss.
Last edited by UDRabbit; Mar 22, 2012 at 09:02 PM. Reason: have you reset it yet? you rECU that is
Old Mar 23, 2012 | 04:25 PM
Cav3man's Avatar
If my ECU did throw a code how to i reset it?
Old Mar 23, 2012 | 04:26 PM
Cav3man's Avatar
I herd something about being able to flash it by disconnecting your battery and that didnt work any other ideas?
Old Mar 23, 2012 | 04:28 PM
ukspice69's Avatar
FUEL PUMP Relay
Old Mar 23, 2012 | 06:37 PM
The Grumpiest
No Start Diagnosis Basics
Sofakingtyte
May 29, 2013 09:04 AM
invisible
Feb 13, 2009 05:34 PM
91sicrxer
17
Jun 15, 2005 08:10 AM
[626]95-GSR
14
Feb 27, 2003 07:45 AM
deeeffache
Oct 28, 2002 03:45 PM
