Sporadic power loss with CEL(but no code)
Old Mar 16, 2012 | 08:23 AM
95BG33PGSR's Avatar
Default Sporadic power loss with CEL(but no code)
Alright im going to make this as simple as possible...at times whether im driving easily and cruising or getting on it my engine temporarly looses all power then comes back to life and sometimes it will happen multiple times and then it will finally throw a cel but it doesnt show a code....when this happens I can sometimes shut my car off then secure the fuel pump (killswitch) crank it to burn out excess fuel then turn the pump back on and then it fires right up often clearing the cel.....does anyone have ANY idea as to what it could be? The only thing I can think of is a faulty ignition system....car has a b18c (stock compression) and some head work tuned on s200
Old Mar 16, 2012 | 08:36 AM
kyden's Avatar
Default Re: Sporadic power loss with CEL(but no code)
will the check engine light blink? last time you did a tune up?
Old Mar 16, 2012 | 08:38 AM
95BG33PGSR's Avatar
No it doesnt when I jump the harness the cel turns off and doesnt blink
Old Mar 16, 2012 | 08:40 AM
95BG33PGSR's Avatar
I replaced the dizzy about a year ago with one from distributer king and replaced plugs roughly 6 months ago
Old Mar 16, 2012 | 07:32 PM
el crapitan's Avatar
year and model?
Old Mar 18, 2012 | 05:29 PM
95CivEXCp's Avatar
Same problem here, I thought I was the only one...
mine is a 95 Civic EX stock.
new plugs, wires, and dizzy.
Old Mar 18, 2012 | 05:56 PM
^^so when you jump the service connector, no code flashes?
but while driving, the cel is illuminated?
Old Mar 18, 2012 | 06:24 PM
95CivEXCp's Avatar
Correct
Old Mar 18, 2012 | 06:45 PM
hmmm. weird. do your clock and radio presets all keep memory?
Old Mar 18, 2012 | 08:55 PM
95CivEXCp's Avatar
yes
Old Mar 19, 2012 | 02:58 AM
95BG33PGSR's Avatar
Yup they do....im so lost right now...i was talking to my friend and he was saying something about the fuel pump but im not sure how it could be...if it was bad wouldnt it consistantly run like crap
Old Mar 21, 2012 | 01:38 PM
95CivEXCp's Avatar
bump:
Old Mar 21, 2012 | 01:59 PM
95CivEXCp's Avatar
oh wait, i think i found my problem...... bad o2 sensor!!!
I will look into it and report back later what i find.
Old Mar 24, 2012 | 07:08 AM
95BG33PGSR's Avatar
Yes please do...i think it could also be a fuel related problem...specically the pump but if thats the case then why is that when the CEL is on it doesnt lose power can anyone answer this
Old Mar 24, 2012 | 10:07 AM
^^so when you say the engine loses all power, what happens to the operations of the gauge cluster? like tach and instrument panel lights. does everything die?
Old Mar 26, 2012 | 11:36 AM
95BG33PGSR's Avatar
Nope...i am pretty sure i found the issue...IACV i unplugged it and the plugged it back in and cel was gone...pulled it off and cleaned it really well im about to go home now so ill know if thats the issue...i after finding the problem i went online and a symptom of a dirty or bad iacv is intermitent powerloss while driving...*crosses fingers*
GPC91
Sep 9, 2012 02:13 PM
Ming Tsai
12
Apr 26, 2007 09:04 PM
totalimpact
Jul 7, 2005 08:39 PM
TurboEG6
Feb 10, 2005 11:03 AM
txhatch
Apr 1, 2002 01:33 PM
