2000 civic si coolant issue
Hi HT,
So during my commute to work my car started smoking, but the temp gauge stays right in the middle where it always is. Get to work pop the hood, there's coolant sprayed everywhere. Now the car is running, parked and there's some steam coming from the radiator but no noticable leaks. I've only ever seen coolant spray like this when a car overheated. I don't quite understand what this might be, any ideas? Thanks.
depends what you mean by checked. i looked it over the best i could given it was right before i had to walk into work. i didnt see any immediate cracks. there was some steam coming off of. again, the gauge wasn't reading overheating though which seems weird to me.
I appreciate the input, so don't take this as argumentative...but given the amount of coolant sprayed throughout the engine, its hard to image that there wouldn't be a noticable leak. Literally there is dried coolant back towards the battery and I will need to add coolant before I drive home. Wouldn't that point to a pretty large leak that I should be able to see when its running? Also what would be causing the radiator to steam? Thanks again.
My 99 si just had this issue last week. My stock radiator cracked, I got a new one from go-autoworks.com for around 118 bucks. Mine never overheated either, but It had a crack in the top of the rad.
I don't claim to know much about cooling systems but wouldn't the pressure throughout the cooling system be the same while the car is idle depending if the fan is off/on?
If at all possible see if you can get a hold of a pressure tester, it'll connect to the top of the radiator and pressurize the system. Sometimes the leak will only be visable when there's pressure, don't go over 15-16psi I believe. Also the cooling fan may have caught what leaked out and slung it all the way to the battery. It could even be a pin sized hole in say the heater hose or something. It's the best way to know for sure.
I hate when people give good advice and people do not want to listen.
Get a pressure tester or have a garage do it for you, that will determine if the radiator is cracked typically at the top.
If it is original most likely cracked.
Perhaps you have trouble reading. I don't think that saying "I'll see if I can find someone with one. I don't think they carry them for rent at most parts stores.....Thanks for your help everyone" qualifies as not listening to good advice. Next time you wanna try to be a stereotypical HT smartass, save for it someone else. Thanks.
A quick phone call would tell you. I don't see WHY they wouldn't have one.
http://www.autozone.com/autozone/ino...tingAndCooling
And a quick Google search.
Yea I'll be stopping at the local autozone on the way home today to see. Less than two years ago I worked at an Advance while I was in college, I know we never carried them for rent. But Autozone's site does say they have them, so I'll check around. Thanks.
That sounds good, those things are a life saver especially if you make a living with them, but whatever you do, just don't buy the radiator from autozone jk, good luck!
