B16a2 in a 93 hatch check engine light
My check engine light comes on after driving a little. It's a b16a2 in a 93 dx hatch. I think it has the stock ecu. Not sure pulled the comp and no makings I can see where they wired in vtec. I did the paper clip method and my light just stays on. Any body know why this is doing that.
And I think it's a obd1 or obd0 but the motor and the wire harness is out of a 99-00 si cuz it has a intake sensor for the intake that connects to the duct to the air box. But doesn't have a 2nd o2 sensor
The problem isn't the ecu. I've had it for a month or so the light comes on when I get on it hard. Car runs fine with this ecu. The problem is y is the code coming on. Codes off when I start the car after a while it comes on. When I check it with paper clip light stays on and shows no code.
Quote Originally Posted by mtber :
Normally your check engine light turns on, then turns off after the fuel pump is primed. If the check engine light stays on, then you are throwing a code. At this time you would then want to jump the service connector to check your malfunction indication codes.
On obd0 if the cel stays red the ecu is bad.
On obd1 if the cel comes on and stays on while car is running then you need to check for code buy jumping plug.
If light is not on during reg driving and you are just testing light,when you jump harness light will stay solid on dash if nothing wrong.
1320king
Jul 22, 2007 12:32 PM
