Bought b16 oem timming belt kit but wasn't oem
Old Mar 13, 2012 | 12:05 PM
DELshaneSOL's Avatar
Default Bought b16 oem timming belt kit but wasn't oem
So I Orderd a timming belt kit for my b16a
It said oem replacement
Came with belt waterpump and tensioner
The belt is gates
Not sure about the tensioner but it says koyo and Japan on it
And the waterpump is gmb
Are these still good to use
Old Mar 13, 2012 | 12:51 PM
gsrturbo-ek's Avatar
Default Re: Bought b16 oem timming belt kit but wasn't oem
oem replacment is after market that replaces oem
honda uses koyo bearings
gates makes good belts.
gmp is good to..so you should be goood to go
Old Mar 13, 2012 | 01:21 PM
Ok thanks
Old Mar 20, 2012 | 03:30 PM
How do I put the new belt and tensioner on
It said to loosen tensioner and retighten it
Turn crankshaft counterclockwise six turns
Ensure timing marks are aligned
Losen tensioner bolt
*turn the crankshaft counterclockwise for 3 teeth on camshaft sprocket
Then torque the tensioner bolt to 40ft lbs
Do I have to do the part marked with *
Old Mar 20, 2012 | 03:37 PM
JDM_teh_WIN!!'s Avatar
Yes. That's what actually tensions the belt. The other part just gets the belt centered on all the gears.
Old Mar 20, 2012 | 03:41 PM
So turn the crank until the cams Go three teeth
Sorry guys
Old Mar 20, 2012 | 03:42 PM
Meh. Yes!
Old Mar 20, 2012 | 03:47 PM
If I went to 4? much would it be tight lol
I'll try out
Old Mar 20, 2012 | 03:50 PM
I dunno, yer supposed to check the deflection of the belt when your done tensioning it. So that'll tell you if it's too tight.
Old Mar 20, 2012 | 03:55 PM
98civdx's Avatar
Master Detailer
Gates actually makes the OEM timing belts. So you are fine.
A OEM timing belt with say Honda and Gates on it.
Old Mar 20, 2012 | 04:04 PM
The belt has nothing on it but
Made in uk 227 37 055 9ds 054 9ds 053 9ds
Is there a special way to check the tightness on the belt
Old Mar 20, 2012 | 04:11 PM
98civdx's Avatar
Master Detailer
grab it and move it around.
You want to be able to move it a bit. Too tight is bad, too loose is bad.
I suggest you get a manual or start doing some research.
Old Mar 20, 2012 | 04:19 PM
bgingras05's Avatar
+1
You really should get a manual. I always go 3 teeth, that's how I was taught at the dealer.
Old Mar 20, 2012 | 04:20 PM
The deflection of the belt should be between 1/2in and 1 in.
Old Mar 20, 2012 | 04:29 PM
Ok yea I just got a book, I've done headgaskets before
This is my first dual cam Honda one
Old Mar 20, 2012 | 04:35 PM
Axatax's Avatar
I purchased an OEM D16 water pump from Honda and the blades were made from sheet metal as opposed to the cast impeller on the original (same part # and all). No picture, it's already installed.
I'm sure it'll be fine but there are aftermarket water pumps that have the beefier blades. Seems kinda cheap.
So, OEM may not necessarily be the best, at least in the case of the new pumps.
high_octane
Apr 3, 2008 06:33 AM
turbolshatch
Nov 28, 2007 03:16 PM
99blackdc2
Jul 13, 2006 08:30 PM
jDMJeRk
Apr 15, 2004 06:58 PM
