Compression test results. Need help! 95 Civic EX
I did a compression check on all 4 cylinders and i was wondering if someone could tell me what the results mean. It has a very bad idle problem if that helps at all. boggy/low idle to be exact.
Cylinder #1: 200psi
Cylinder #2: 180psi
Cylinder #3: 160psi
Cylinder #4: 120psi
Also, there seems to be no fuel getting to cylinder #3.
Cylinder #1: 200psi
Cylinder #2: 180psi
Cylinder #3: 160psi
Cylinder #4: 120psi
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
the leakdown will show where the leak occurs. the problem could be of many, valves, rings, intercylinder leak.
trecool44
Jun 19, 2007 06:52 AM
