Doing rear disc conversion ek coupe would I need teg springs in rear?
Old Mar 9, 2012 | 06:02 PM
tyfoxx0608's Avatar
Default Doing rear disc conversion ek coupe would I need teg springs in rear?
I just bought rear trailing arms from 94-01 integra. If I were to lower the car would I need ex springs in front and teg springs in the rear?
Old Mar 9, 2012 | 09:00 PM
Marvin1985's Avatar
Default Re: Doing rear disc conversion ek coupe would I need teg springs in rear?
The springs/shocks on both those cars are the same dude so to answer your question NO.
Old Mar 9, 2012 | 09:03 PM
Marvin1985's Avatar
Also get a 4040 prop valve. Look it up. You need this for the brake swap
Old Mar 9, 2012 | 09:16 PM
tyfoxx0608's Avatar
Yep already got the 4040 prop valve from a cx and thanks for the clear up
Old Mar 9, 2012 | 09:37 PM
Libertariat's Avatar
Ek Forever y0!
If you have a 96-00 civic you DO NOT need to change the prop valve. Period.
Don't waste your time.
When I swapped rear integra trailing arms onto my 2000 civic, all I kept was the civic suspension, and the civic toe compensator arms.
I have s2000 front calipers for brakes, and integra rears. I didn't swap prop valves, and the car bakes amazingly in autocross.
A buddy of mine has had 44 brake setups on his 96 sedan, and has never seen the need for a prop valve swap.
Old Mar 9, 2012 | 09:49 PM
98civdx's Avatar
Master Detailer
Sell it.
By part numbers the EX does have a different prop valve in it, however, you will see no gain by replaceing it. Really, if someone tells you different they don't know what they are talking about. I am speaking from experience when I say there is noithing to gain.
Keep everything from the car, except for the trailing arms, brake lines, e brake lines.
keep your toe arms, upper and lower control arms.
Old Mar 11, 2012 | 08:10 PM
tyfoxx0608's Avatar
Damnit after reading so many forums and diy I was for sure I needed the prop valve lol. Guess Ill sell it, I should be able to at least get my money back.
Old Mar 11, 2012 | 08:15 PM
Fliptard's Avatar
The only thing you would possibly need to change is the brake master cylinder to at least a 7/8. If you have a 13/16 it MAY give out after awhile. But then again, it might not.
Old Mar 11, 2012 | 08:20 PM
tyfoxx0608's Avatar
I have a 99 ex so would I need to change the MC? Since from what i read ex are pretty close to si.
Old Mar 11, 2012 | 08:44 PM
tyfoxx0608's Avatar
Think it was 14/16 for the ex?
Old Mar 11, 2012 | 08:59 PM
98civdx's Avatar
Master Detailer
Wrong. He does not need to change it, the EX is the same as the SI.
Nope. The EX/SI both share the same MC. They have the same front brakes.
Old Mar 12, 2012 | 05:02 AM
Fliptard's Avatar
Yea, an EX is a 7/8 so you should be good.
Chefskinny
Apr 15, 2015 05:48 PM
nicky352
Dec 20, 2010 03:43 PM
98GSR-Turbo
May 16, 2008 02:03 PM
BmoreCivic
Jul 2, 2006 04:59 PM
bradykiller
Northwest (Sales)
Nov 14, 2005 07:50 AM
