Headlight Bulbs
I was looking at changing out the "stock" bulbs that come on the EK civic. The light out put well, i guess we can say sucks. I am not going to go the HID route because HIDs need to be done 100% correctly and it is not cheap to retrofit. I was looking at the Philips 9003 XPS2 X-treme Power. Has anyone used them? I saw pictures and they look great, but most posts were from 2007. Did anyone have issues with the plastic melting inside the housing? Wires burning up? Bad life expectancy on the bulb? Thoughts?
http://www.amazon.com/Philips-9003-X...ar=1&carId=001
Trust me, http://www.powerbulbs.com/us/product...eadlight-bulbs
Best $50 you ever spent.
This is the newer version of the bulb. Much better than the older one you listed.
Thanks how much more light output over the older version? I read the life of the bulb is even shorter. Do you know how long? And if possible do these actually hit 4000? I was hoping for a Philips X-treme Power vs X-treme Vision but do not see any.
I have seen pictures of the Osram and I am not impressed. Phillips in my opinion has received more recommendations and provides more light output then all the others. Again this is my opinion, can not find any facts, hence why I asked my questions :-)
I still have my Osram nightbreakers that I had before I had my two sets of phillips.
The osrams don't hold a candle to either of the phillips.
Not even close.
Not even close.
Some people with PIAA bulbs with higher wattage have issues in fog housings, but the civic housings are pretty open.
No issues here.
