Rear Top Hat
Old Mar 7, 2012 | 01:27 PM
stretchum's Avatar
Default Rear Top Hat
hey guys got a quick question. i have a 97 ek hatch and i been hearing werid sounds all week comeing from the rear end. today i hit a pretty good hump in the road and heard something smack the plastic in the trunk. i pulled over and looked in the trunk and the rubber peice that sits inside the top hat shot out. only thing there was the strut and nut holding it on. question is why would that peice shot out like that?
Old Mar 7, 2012 | 01:44 PM
MRGRIM's Avatar
R.I.P. Mark
Default Re: Rear Top Hat
seized shock or bottoming out the shock
rubber fail due to old age
but id look at shock 1st
Old Mar 7, 2012 | 01:51 PM
stretchum's Avatar
ok thanks. ill start by looking at the shock. how would i know if the shock is bad? there isn't any fluid comeing out or anything. i did fell to say i just had new shocks put on by the way.
Old Mar 7, 2012 | 02:00 PM
jbpnoman's Avatar
Easiest way I've found to test a shock or strut is the bump test. Push down on the corner of the car a few times, get it bouncing, and then let go. If it takes more than 3 up/down motions to come to rest, something's blown.
Old Mar 7, 2012 | 02:28 PM
MRGRIM's Avatar
R.I.P. Mark
^^^ if i did that test on myn there all seized it dont move ... lol
Old Mar 7, 2012 | 02:29 PM
MRGRIM's Avatar
R.I.P. Mark
where they ment to be stiff ..if so then that would be the cause
did the top hat rubbers get replaced at the same time ??
Old Mar 7, 2012 | 02:42 PM
98civdx's Avatar
Master Detailer
The assembly was put togther wrong.
Remove the shock from the car.
my guess is that the ring that is under the top mount is not there.
It slides onto the piston, and the mount sits on it. if you look at the shock, you will see the bump stop, then the ring(if it's there)
EDIT- Post a picture
Old Mar 7, 2012 | 03:13 PM
dumafit's Avatar
post a picture so we can get a better idea of what is wrong
Old Mar 7, 2012 | 04:59 PM
stretchum's Avatar
There was no ring. The ring ur talking bout looks like a washer right the driver side has one and the one that popped out doesn't. I called the guy back at free tire and service and he said he forgot to put it back on lol. Damn near screwed my damn car up but he did say sorry lol. I'll never deal wit them again.
Old Mar 7, 2012 | 05:19 PM
98civdx's Avatar
Master Detailer
Yep it looks like a washer. Not putting that back in allowed the bump stop to travle up and smack the lower bushing in the top mount, causeing the upper to pop out.
Simple fix. Make sure he doesn't charge you for his screw up.
Old Mar 7, 2012 | 07:22 PM
jbpnoman's Avatar
Then you need to work your puny arms and put more pressure into it. I've yet to see a car in the shop, modified or not, that I couldn't bounce test. It's a standard part of VA state inspections.
citrus3000psi
Oct 10, 2005 10:39 AM
_Cyclone_
Mar 23, 2005 04:54 PM
GroundZer0
14
Mar 18, 2004 12:12 PM
alfaaay
Mar 31, 2003 06:21 PM
