98 Civic ex/b18b1 swap - Could my timing belt have slipped a tooth on the crank gear?
Old Mar 7, 2012 | 11:46 AM
Cap'N Chronic's Avatar
Default 98 Civic ex/b18b1 swap - Could my timing belt have slipped a tooth on the crank gear?
So today my car started getting a weird vibration whenever it is stopped and idling. I looked under the hood and my engine seems louder than it normally is, a lot of metallic sounds. My timing belt used to be somewhat loose between my exhaust cam and crank gear and now its is pretty much tight. Could my timing belt have slipped a tooth on the crank gear?
Old Mar 7, 2012 | 11:52 AM
98civdx's Avatar
Master Detailer
Default Re: Could my timing belt have slipped a tooth on the crank gear?
Try to set TDC and check...
Old Mar 8, 2012 | 04:23 PM
From what I can tell the vibration is coming from my transmission. It sounds like a bearing is going bad. what would be making that noise? And it only does it when its idling, perfect any other time. Is there a ilder bearing in si transmissions?
Old Mar 8, 2012 | 04:30 PM
vitamin_c95's Avatar
Pedal in or out? Pedal in is throw out bearing. Pedal out is input shaft bearing
Old Mar 8, 2012 | 07:44 PM
Well it's both, it's getting worse now too, I can feel it through the whole car.
Old Mar 12, 2012 | 08:22 AM
I just got done investigating for almost an hour and I still cannot find the source of the vibrating.
It doesn't do it all the time, only when the engine is under 1k rpm's. I can only feel it in the pedals, and whenever I look in the engine bay, I don't see or hear anything abnormal that would make the pedals vibrate like that.
If it was a transmission bearing, would I be able to feel it in the shifter? I'm assuming the vibration from the transmission would transfer up through the shift linkage.
I'm starting to think it's coming from my alternator, since at night I can see my lights get dimmer and brighter when going from low to high engine loads, ect. Is it possible the vibration could be caused by a bad alternator bearing or something similar?
Old Mar 12, 2012 | 11:33 AM
I've confirmed that the noise and vibration is not coming from the transmission.
My engine oil was about half full, and there is oil leaking out from under my oil filter and a couple other spots. I think the noise is due to low oil pressure/levels.
Former User's Avatar
Are we talking about a stock 98 Civic? If so, you must include that information in your first post.
You MUST provide all pertinent information about your car and engine. Failure to do so may result in thread closure.
Old Mar 12, 2012 | 06:49 PM
My bad, car is a 98 ex with a b18b1 swap.
boostedteg4dr
Feb 25, 2014 08:39 PM
phil1039
Feb 16, 2014 06:47 PM
bretthuff0
Dec 29, 2010 12:28 PM
rasinhell
16
Feb 7, 2008 05:29 AM
Calvinator
Sep 18, 2004 05:09 PM
