Replacing a 1996 D16Y8 with a 2000 D16Y8
Old Mar 7, 2012 | 06:47 AM
gmanns's Avatar
Icon6 Replacing a 1996 D16Y8 with a 2000 D16Y8
What kind of headaches can I expect while attempting this swap. Both are manuals.
Will I have to locate a 2000 EX ECU? and will I need an adapter? or can I use an adapter of some kind to reuse the origional one?
I presume that I should use the '96 wiring harness, distributer and related sensors.
Any difference in performance between the two?
Old Mar 7, 2012 | 06:52 AM
Marvin1985's Avatar
Default Re: Replacing a 1996 D16Y8 with a 2000 D16Y8
So your car is a 96 and your using the 00 motor? Use the 96 distributor and your original harness for the 96. Idk what else needs changed other than you need a jumper harness from obd2b to obd2a.
Old Mar 7, 2012 | 06:54 AM
gmanns's Avatar
What will the jumper enable me to connect?
Old Mar 7, 2012 | 07:02 AM
Marvin1985's Avatar
Your 00 ecu. Although you could more than likely still use your 96 ecu since same motor. The 00 one is just a newer obd and looks for more sensors. I was assuming that you were switching ecu's as well.
Old Mar 7, 2012 | 07:18 AM
gmanns's Avatar
Thanks for the quick reply Marvin,
This all makes perfect sense. I can simply make the 00 D16Y8 resemble a 1996, so the '96 ECU should never know what happened.
I presume that the '96 harness will plug into the 2000 crank trigger as well as the injectors and other related stuff?
I have installed several Civic engines, but have felt uneasy because Car-Part.com interchange lists the '99 and 2000 engines seperate from the 96 thru '98.
I wonder what the difference is?
Old Mar 7, 2012 | 07:26 AM
HondaPartsHero's Avatar
Technical Hero
Everything's the same, same sensor and all. The only differences I know of is that the 99-00 uses an air injection system but its mechanical and won't affect the ecu. And distributor plugs are different so just reuse yours. Also the 99-00 exhaust manifold is better as well on the 99-00 Y8. This is assuming the 99-00 your getting is a manual or auto engine, is your current engine auto or stick?
Old Mar 7, 2012 | 07:34 AM
gmanns's Avatar
Manual to manual, I will have to reuse my old exhaust manifold though, it was not included in the engine purchase.
Old Mar 7, 2012 | 07:40 AM
Marvin1985's Avatar
only difference is OBD2A (96-98) OBD2B (99-00) use your 96 distributor. everything else will plug right up.
Old Mar 7, 2012 | 07:46 AM
Arthas's Avatar
Use your 96 distributor, 96 engine harness, and 96 ECU.
Old Mar 7, 2012 | 09:02 AM
phat00civic's Avatar
I am curious why your doing this swap? Just need a newer motor? Less miles?
Old Mar 7, 2012 | 12:02 PM
motegicivic's Avatar
I assume the motor will have the intake manifold right?
Old Mar 7, 2012 | 01:44 PM
apexi_rsx's Avatar
if the car is running a 96 ecu u must use the old 96-y8 ecu because the newer intake manifold have air injection and this ill create a vacuum leak.
Old Dec 9, 2020 | 09:02 PM
Mikes96ek's Avatar
question i have a 96 ek hatch when i got it it had a 98 y8 in it but had to sell my motor. Just got a 00 y8 out of a auto ek coupe what intake manifold do i need to get it running right
sykomatik
Aug 1, 2015 05:11 PM
loso916
Aug 15, 2014 02:37 PM
gunnrun9
Mar 19, 2011 03:07 PM
exotic_type
Apr 18, 2008 10:35 AM
Eaglekper0046
Sep 27, 2005 09:41 AM
