How do you tell if an Oil Pump is bad?
Old Mar 6, 2012 | 05:28 PM
beatontheeznutz's Avatar
Default How do you tell if an Oil Pump is bad?
like the title says... how do you tell if an oil pump is bad?
Old Mar 6, 2012 | 05:37 PM
seanbev24's Avatar
Default Re: How do you tell if an Oil Pump is bad?
The first thing I'd do is change the oil and filter, and then check your oil pressure with a mechanical gauge. If the gauge reads low, I'd remove the oil pump. There are clearance specs you can check with feeler gauges.
Old Mar 6, 2012 | 05:38 PM
seanbev24's Avatar
What makes you think it's bad?
Old Mar 6, 2012 | 05:45 PM
motegicivic's Avatar
Sometimes the oil light will come on the dash.
Old Mar 6, 2012 | 05:59 PM
Libertariat's Avatar
Ek Forever y0!
Have you checked the oil level?
Old Mar 6, 2012 | 06:32 PM
where would i put the oil pressure gauge? what readings should i aim for on the gauge? do i check it while the car is running/idling? do i rev it to a certain rpm? sorry never done it before. if someone could explain the procedures. engine is a '95 GSR. Oil is still pretty new... still has a bronze film to it. hitting rev limiter at 7k. engine doesn't like reving from 5k RPM and up...gets very sluggish even it first gear.
Old Mar 6, 2012 | 07:36 PM
Arthas's Avatar
Well for one if you suspect the oil pump is bad I wouldnt rev the engine at all. That is your lifeline lol
Old Mar 6, 2012 | 07:40 PM
Ek Forever y0!
Old Mar 6, 2012 | 08:13 PM
yes just did oil change a few weeks ago and the oil level is fine. no leaks.
Old Mar 6, 2012 | 09:10 PM
seanbev24's Avatar
You would temporarily remove the oil pressure sending unit and install the gauge in it's place.
superspadez
Aug 31, 2012 01:38 PM
EG6 Love
Feb 6, 2010 09:53 AM
nihad
13
Jul 17, 2009 05:45 AM
j954drgsr
Sep 19, 2005 12:55 PM
cornholioEK
Jan 17, 2003 02:52 PM
