JVT Radiator/Fan 94 sol VTEC
Old Mar 5, 2012 | 11:21 PM
OmgDelSol's Avatar
Default JVT Radiator/Fan 94 sol VTEC
Hi everyone. I was looking to replace my cooling fan and figured i might as well replace the radiator as well. Has anyone dealt with JVT products? Or is there another brand i should look into. Not needing to cool a track car just a DD. Thanks
Old Mar 5, 2012 | 11:49 PM
jbpnoman's Avatar
Default Re: JVT Radiator/Fan 94 sol VTEC
Just get one from Advanced with a lifetime warranty and call it a day. No need to waste money on an "upgraded" radiator, other than bling factor.
Old Mar 6, 2012 | 03:40 AM
NVturbo's Avatar
O.G. triple O.G.
Originally Posted by jbpnoman
.............. No need to waste money on an "upgraded" radiator, other than bling factor.
That's the dumbest comment I've heard in a while. Do you know why companies make radiators out of aluminum instead of the usual aluminum with plastic upper compartment? Might want to read up on that before making such comments without facts behind it.
Old Mar 6, 2012 | 03:53 AM
grumblemarc's Avatar
The Grumpiest
I don't know about you but my cooling capacity greatly improved when I upgrade to the setup I have now.
Old Mar 6, 2012 | 04:36 AM
jbpnoman's Avatar
Did you miss the part where he said he was just doing this as a DD? I don't see you backing up your claims with any proof, either. Stock or stock replacement is just fine for DD repair and maintenance. There is absolutely no reason to spend $150+ when you can get an OE replacement from Advance for half that, on a non-modified car.
Old Mar 6, 2012 | 04:57 AM
mayfly's Avatar
actually the 92-00 hondas are known for running a little hotter than the other year civics. they put blame to the small radiator.
also OP JVT is very good
found this: http://www.importtuner.com/tech/impp...s/viewall.html
Old Mar 6, 2012 | 07:46 AM
NVturbo's Avatar
O.G. triple O.G.
If you can find an OEM replacement from Advance Auto for under $100, I will gladly pay for it. Those things are at least $100 the last time I bought one a few years ago. For $75 more, you can get an ALL-ALUMINUM Mishomoto radiator and dont have to worry about cracks or leaks.
Read this post and give me your logical response why stock or OEM are so much better than all-aluminum radiators.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/99-civic-radiator-fan-problem-2733477/
Old Mar 6, 2012 | 09:01 AM
dpetro1's Avatar
the real question is...why are you replacing the fan in the first place? is the motor broken? the blade broken? oem fan w/ oem shroud is going to be way better than most aftermarket fans and you can easily find a replacement at the junk yard.
Old Mar 6, 2012 | 12:10 PM
lordhelmet1584's Avatar
https://honda-tech.com/forums/showthread.php?t=2733477
$79.99
http://www.autozone.com/autozone/par...3860_266503_0_
What the heck did your link have to do with comparing oem to all aluminum?
Old Mar 8, 2012 | 12:14 PM
OmgDelSol's Avatar
[QUOTE=dpetro1;46980648]the real question is...why are you replacing the fan in the first place? is the motor broken? the blade broken? oem fan w/ oem shroud is going to be way better than most aftermarket fans and you can easily find a replacement at the junk yard.[/QUOTE
I noticed that my car was running a little hot while idleing. Checked under the hood and my fan wasn't working. Checked fuses and they were all good. So i swapped the Rear defroster relay with the cooling fan relay and nothing. Figured the fan just went out. I have receipts of everything replaced on the car, and the radiator and fan wasn't in that list. Might as well replace both at the same time.
Old Mar 8, 2012 | 05:43 PM
dpetro1's Avatar
Did you try jumping the fan connector at the switch on the thermostat? You should confirm the fan is actually broken before replacing it. There are other pieces of he system that could cause the fan not to come on that haven't been checked.
Old Mar 8, 2012 | 09:07 PM
OmgDelSol's Avatar
No i haven't but i'll be sure to check it when i get a chance and report back in.
Old Mar 9, 2012 | 04:43 AM
dpetro1's Avatar
Link with additional troubleshooting steps
http://techauto.awardspace.com/overheating.html#nofan
Old Mar 9, 2012 | 09:15 AM
1997civicdxcoup's Avatar
Iv never had a problem with my ebay radiator. 60$ for one.
Old Mar 14, 2012 | 06:07 AM
OmgDelSol's Avatar
What's your current setup grumble. How much modification is needed.
Old Mar 14, 2012 | 10:49 AM
dpetro1's Avatar
did you ever troubleshoot/fix the fan
Old Mar 15, 2012 | 08:34 AM
OmgDelSol's Avatar
I looked at the troubleshooting link u posted. One of the fans run when i turn on the AC. My fuses are good. As fast as jumping the wire, i couldn't figure out the wire i needed to short. Is the the wire on top of my cooling fan next to my overflow reservoir?
Old Mar 15, 2012 | 08:50 AM
dpetro1's Avatar
no. look on the thermostat housing. there is a 2-pin connector. this is the fan switch (thermoswitch). simply use a paperclip or piece of wire and connect the two terminals on the plug connector.
Old Mar 15, 2012 | 09:24 AM
OmgDelSol's Avatar
Ok i'll check that out. I'm new to cars so idk exactly what i'm looking for. I'm sure ill find it. I think i heard it's on the backside of the block right?
Old Mar 15, 2012 | 10:03 AM
dpetro1's Avatar
yes. follow the lower radiator hose to the engine block. this is the thermostat housing.
Old Mar 15, 2012 | 10:07 AM
OmgDelSol's Avatar
Lol alright thanks man. I'll be checking it when i get off of work in the morning. If i decide to buy the JVT Radiator/Fan will it all bolt right up? Or am i going to have to do a few things before it fits right.
Old Mar 15, 2012 | 10:33 AM
dpetro1's Avatar
the radiator should fit right in. if you decide to switch to the slim fan, those are generally universal and will need to be mounted to the radiator with zip ties/ mounting brackets
Old Mar 15, 2012 | 10:32 PM
OmgDelSol's Avatar
Ok Maybe i should stick with OEM fans and just buy new ones.
Old Mar 16, 2012 | 09:44 AM
dpetro1's Avatar
i think you should just fix the fan and leave the oem radiator. easiest and cheapest fix
Rafe Altschuler
14
Aug 11, 2015 04:10 PM
eightvalver
Sep 22, 2007 01:17 PM
dAng! Kris
Apr 6, 2005 07:40 PM
ares650
Sep 22, 2004 10:22 AM
