radiator question
Old Apr 6, 2005 | 04:20 PM
dAng! Kris's Avatar
Default radiator question
I got my integra and I need a new radiator and fan. I was looking at the fluidyne or koyo radiators. Now for the question I want the half size one with the FAL fan. So I would just need the civic half size radiator and the fal fan for the civic radiator, right? TIA
Old Apr 6, 2005 | 04:30 PM
Evanmb44's Avatar
Default Re: radiator question (Frozty)
you want to get the vtec radiator out of the del sol. this radiator is a dual core and allows it to cool in your integra well. i run this radiator. check out radiatorbarn.com, that is where i purchased my radiator. cost 90 bucks or so and got to my house in like 2 days. i was very pleased. as for the slim fan, any 12in slim fan will work. there are a couple people on honda-tech that sell them for around 60bucks i believe. this should get you what you are looking for.
Old Apr 6, 2005 | 04:36 PM
dAng! Kris's Avatar
Default Re: radiator question (Turboaddict)
ok so what would work with using a fluidyne/koyo radiator and fal fan. which car would i need?
Old Apr 6, 2005 | 04:40 PM
Evanmb44's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frozty &raquo;</TD></TR><TR><TD CLASS="quote">ok so what would work with using a fluidyne/koyo radiator and fal fan. which car would i need?</TD></TR></TABLE>
get one that is an exact replacement for the del sol vtec radiator.
why dont you just go with the oem one. it cools fine and is much less expensive
Old Apr 6, 2005 | 05:00 PM
dAng! Kris's Avatar
I prolly will cuz I"m always down for saving some money. Is it the same size thickness wise at the fluidyne or anything cuz with the way my turbo sits right now its a tight fit
Old Apr 6, 2005 | 05:15 PM
Evanmb44's Avatar
the one i have, which is the same one i told you to get, measures about 1.5in thick for the core and a little over 2in thick at the top. i went out and measured for ya.
hope that helps you figure out your fitment. it should be able to fit in there
Old Apr 6, 2005 | 05:23 PM
dAng! Kris's Avatar
del sol radiator = plastic or aluminum?
but if it comes down to it i just need to get a del sol vtec fluidyne half size radiator or a basic civic eg or ek radiator? I'm askin for multiple parties not just my car.
Thanks for all your help tho
Old Apr 6, 2005 | 05:49 PM
Evanmb44's Avatar
yes it is the del sol vtec radiator. make sure it is the vtec one because that one is the dual core on oem
Old Apr 6, 2005 | 05:55 PM
dAng! Kris's Avatar
so for the fluidyne is the del sol vtec is what i order
Old Apr 6, 2005 | 06:19 PM
Evanmb44's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frozty &raquo;</TD></TR><TR><TD CLASS="quote">so for the fluidyne is the del sol vtec is what i order</TD></TR></TABLE>
yes, you would want one that is the same size as stock so that is what to get.
Old Apr 6, 2005 | 06:36 PM
dAng! Kris's Avatar
same size as stock as in stock teg or stock del sol.? lol. . . cuz i need a half size so i can have it on the side instead of takin up the whole front so i can fit my equal length mani there
Old Apr 6, 2005 | 07:07 PM
Evanmb44's Avatar
same size as the stock del sol one
Old Apr 6, 2005 | 07:08 PM
dan_w_82's Avatar
Your gonna need a delsol 2 core radiator no matter if it's stock or the koyo or whatever radiator you get. Make sure it's the delsol SI vtec and your set. I had a long radiator in my civic for 2 years and just went turbo and did the same thing......Except I went with a Autozone factory replacement with Lifetime warranty and added some water wetter. You can't complain about $90 and having lifetime warranty and the Redline water wetter is working pretty good also. Mine has never got hot at all with my setup. GL on your decision
Old Apr 6, 2005 | 07:30 PM
dAng! Kris's Avatar
Default Re: radiator question (dan_w_82)
was looking online a koyo and fluidynes and it just says civic and del sol, no si vtec or anything like that. Could someone just post up a link to what I"m tryin to find. I feel really retarded right now
Old Apr 6, 2005 | 07:40 PM
dan_w_82's Avatar
Maybe on the aftermarket radiators there all the same size core except the length is longer on some....Just call up the places where your looking at buying from and ask.....
eightvalver
Sep 22, 2007 01:17 PM
95LSS
Jul 24, 2006 06:35 PM
4piston
Jan 27, 2005 07:11 PM
326PWR
May 8, 2003 10:45 PM
