99 Civic/B18b1 swap - doesn't run great and throws TPS code
Hey guys, I just took my car for a ride since installing a b16 head on my ls bottom and it doesn't run that great!
History: I'm not a mechanic and have been learning as I go. I had a b18b1 installed in my 99 civic sedan about a year ago. Since then I wanted to turn it into a lsvtec so I researched like crazy and tackled the project myself.
Symptoms: car seems like it wants to die at idle and has died the odd time. There is a little vacuum pin port at back of intake mani that I have to leave open or it won't stay running. Car sounds rough and seems fairly powerless. At about 5k rpm the engine bogs and engine makes a high pitch noise, not squeal.
It's throwing a tsp cel so, I thought this might be the issue so I did a search and learned how to check it. I got a multimeter and here's the numbers I got: continuity- 10
Throttle closed- .48v
Throttle open- 4.4v
The throttle open seems a bit low could this be my issue?
I'm stumped and could use some help, any help would be appreciated! And foe the record grumblemarc I've done my research lol
Throttle open- 4.4v
Oh, I should also mention that the vtec is not wired up yet and ecu is not chipped, I will be bringing it in to have this done but wanted it running right before I do!
Thread titles MUST summarize the tech problem so that members browsing titles can easily understand the problem without reading the post -- Title edited.
The car ran fine before changing the head, I cleaned the iac out today just to try it but didn't change anything!
Andrew Ryan P
Mar 20, 2017 07:48 PM
calvin924597
25
Jan 10, 2014 06:37 PM
Hmotoredcoupe
Apr 14, 2013 07:41 PM
Vtec Civic 93
12
May 29, 2010 04:09 PM
ezeedude
16
Feb 26, 2008 12:06 PM
