New hardware for header install
Old Feb 28, 2012 | 09:36 PM
JasinC19's Avatar
Default New hardware for header install
I would like to get new hardware for a header install.
Is the stock manifold held on by all studs/nuts? Mix of studs and bolts?
How many of each do I need for a full replacement?
This is for a 2000 Civic Si B16A2
I saw another post say it requires the following:
7 x 90001-P30-003 Bolt, Flange
2 x 90026-PE0-000 Bolt, Stud
2 x 90212-RCA-A01 Nut, Self-Lock
Can anyone back this up?
Thanks
This schematic wasn't very clear:
http://www.hondaautomotiveparts.com/...28DOHC+VTEC%29
Old Feb 28, 2012 | 09:38 PM
grumblemarc's Avatar
The Grumpiest
Default Re: New hardware for header install
? What part isn't clear?
Old Feb 28, 2012 | 09:46 PM
JasinC19's Avatar
The stud part #'s are different as are the quantities in the schematic vs that guy's post.
Also if I am installing a 1 piece header I am assuming I would only need 2 out of the 3 the schematic is calling for.
Plus I just want a human being that knows the answer to tell me instead of buying things I might not need.
Old Feb 29, 2012 | 12:07 AM
JDM_teh_WIN!!'s Avatar
I usually run 9 studs and 9 nuts.
9 x 90026-PE0-000 Bolt, Stud
9 x 90212-RCA-A01 Nut, Self-Lock
But you can do it either way. The parts above are studs that get threaded into the block and a nut that threads onto that.
The other way has 7 regular bolts and 2 studs and 2 nuts on either end of the header flange.
Really up to you how you want to do it. I like the 9x9 way. It looks cleaner.
Old Feb 29, 2012 | 06:17 AM
motegicivic's Avatar
You probably could use the exsiting studs on the car now, just get new nuts, unless the studs are damaged.
Old Feb 29, 2012 | 06:20 AM
JasinC19's Avatar
I'm not sure. They have never been messed with. I think I have the only EM1 left with the stock exhaust manifold.
But yeah if the studs are like any of the other bolts on the car, I'd just rather replace them while I have them header off.
Old Feb 29, 2012 | 07:06 AM
kyden's Avatar
on obd2 b series you have 7 bolts and 2 studs.
Old Feb 29, 2012 | 07:24 AM
JasinC19's Avatar
Thanks guys. Much appreciation.
socialistic
Oct 30, 2010 11:55 PM
jeremyrocksursox
Jan 3, 2009 07:31 PM
Autoworks
Acura TL, RL & ZDX
Mar 17, 2007 09:11 PM
migizzel
Oct 2, 2005 07:09 PM
GSRacer93
Dec 31, 2003 09:26 AM
