D15b7 Low idle
Old Feb 26, 2012 | 11:57 AM
Lozano1991's Avatar
Default D15b7 Low idle
Need help.. I need to know everything that can cause this so I can check it out.
Thank you.
Old Feb 26, 2012 | 12:07 PM
Lozano1991's Avatar
Default Re: D15b7 Low idle
All I know is it could be the timing or a leak. But I want to know if theirs any thing else that can cause this.
Old Feb 26, 2012 | 12:24 PM
grumblemarc's Avatar
The Grumpiest
Define "low idle". You might want to furnish way more info than you have.
Old Feb 26, 2012 | 12:34 PM
T_ypEr's Avatar
Agree with above. How low is "low"? I mean, the warmed up idle speed is already pretty low (mind hovers at about 500rpm when it's all warmed up) so I'd say you must be really close to stalling....
Old Feb 26, 2012 | 12:38 PM
Lozano1991's Avatar
Well the thing is, it's automatic and when I put in drive after warmed up, it seems to idle lower than usual. Plus I dont have a mph on my cluster so I can't tell. But I know it's lower than usual.
Old Feb 26, 2012 | 12:59 PM
The Grumpiest
WTF is "low idle"? WTF is "seems"? You haven't even bothered to give us a number! What RPMs are YOU calling low?
T_ypEr's Avatar
You mean you don't have a tachometer? (RPM)
The idle is supposed to drop when the car is warmed up. The only reason the idle is high is to warm up the engine. You'll notice that your car shifts at a higher RPM when it's cold. This also helps warm up the engine. When the engine is warm the RPMs drop automatically. But if it feels and sounds like it's about to die, then there may be something out of adjustment.
Old Feb 26, 2012 | 01:04 PM
The Grumpiest
If you don't have a tach and you aren't throwing any codes then how do you know there is a problem? We cannot troubleshoot "seems".
Lozano1991's Avatar
Yes! I have no tach!!!
That's why I can't give you a number
And yes I know how it works to warm up and stuff.
But I know my car and all I wanted to know is what kind of "adjustments would it probably need?
I know its idling low.
Old Feb 26, 2012 | 01:06 PM
The Grumpiest
When was the last tuneup you performed?
Next time list all car details in the first post as per the rules. It saves a lot of guesswork and frustration.
Old Feb 26, 2012 | 01:09 PM
T_ypEr's Avatar
Without a tach, it's going to be really hard to diagnose since you don't have something measuring the engine speed. Do you have a shop manual? Try the troubleshoot section in it.
BTW, what kind of car is this? No tach and automagic tranny means a CX, I assume? Just a guess...
Lozano1991's Avatar
Well first off, you don't need a CEL code most of the time to tell you theirs a problem.
for example, like a blown head or a vacume leak. Or when the timing is off.
Old Feb 26, 2012 | 01:11 PM
T_ypEr's Avatar
Maybe I picked the wrong word then.... I think what I meant to say was "hard to test" since you don't have a tach to check and make sure the engine speed is correct to spec.
Lozano1991's Avatar
It's a 95 dx civic hatch.
And yes sorry about the rule. I'm new.
Old Feb 26, 2012 | 01:13 PM
The Grumpiest
Vacuum leak will usually get you a higher idle.
When did you do a tuneup last?
Old Feb 26, 2012 | 01:14 PM
T_ypEr's Avatar
Don't worry. As long as you learn something from it, it's not a mistake.
Old Feb 26, 2012 | 01:15 PM
Lozano1991's Avatar
By tune up I did
Spark plugs/wire
Oil/intake filters
Which was done about 18k miles ago and I always do my oil changes every 3k
Is their anything else I missed on my tune up?
Old Feb 26, 2012 | 01:17 PM
The Grumpiest
Cap. Rotor. Fuel filter.
Old Feb 26, 2012 | 01:21 PM
Lozano1991's Avatar
Oh yes and I did the fuel filter also
But the cap and rotor no.
Maybe when I do that I'll go and check the timing as well.
Should I buy a tach from auto zone or any place to help me with the rpm?
And if I do would it hook up to the car even though it originally didn't have one ??
Old Feb 26, 2012 | 06:55 PM
Lozano1991's Avatar
Any one?
Old Feb 26, 2012 | 09:31 PM
T_ypEr's Avatar
Cap and rotor might do it.... But I think timing issues would cause a misfire or something. If the tach is just for the fix, don't waste your money. If you do get one, it should hook up to the car. You might have to look at some diagrams and wire some stuff, but it should work.
Old Feb 26, 2012 | 09:43 PM
Damanzi's Avatar
you can get a cluster from an ex model 92-95 it will have a tach and it will be plug and play. you can even swap your speedo into it to keep your mileage.
Old Apr 2, 2012 | 10:11 PM
Lozano1991's Avatar
Icon2 My set up!
What do you think? Just to know if this is cool to run.
Obd1 pr4 ecu , hush22 hydro kit, hasport motor mounts, sway bars as well as coil overs
Ok I got a high cr b20b with gsr and cat
2.5 rsr exhaust with resonator
Aem intake and a b18a1 intake manifold & tb
Jdm ls tranny with p30 flywheel and a stage 1 clutch
rockycat
Honda Civic (2006 - 2015)
Feb 19, 2015 04:16 PM
92_JDM
Engine Management and Tuning
Aug 12, 2010 03:23 PM
wuggiewuggie
Sep 22, 2007 08:09 AM
TheNasty0ne
Dec 17, 2005 01:07 PM
