D16y7 ticking and burning oil.... New head?
Old Feb 25, 2012 | 02:30 PM
osbunjosh's Avatar
Default D16y7 ticking and burning oil.... New head?
I got this car with about 220k on it. Now it has 230k and its ticking from the valves. So the other day I took it to the shop and did a valve adjustment. Didn't help at all. And now I'm realizing its burning quite a bit of oil. Now should i just take a chance and buy another y7 head or just try and swap it out?
This is my daily so I'm just looking for some feedback.
Old Feb 25, 2012 | 02:35 PM
Blacknight117's Avatar
Default Re: D16y7 ticking and burning oil.... New head?
It sounds more like your rings are gone. Do a compresson test and see what the numbers are and post them here..How often do you have to add oil?
Old Feb 25, 2012 | 02:38 PM
osbunjosh's Avatar
About every other week. Im at work now so tomorrow ill get a compression test and post the numbers here
Old Feb 25, 2012 | 03:32 PM
Better question would have been, how much oil do have to add?
Old Feb 25, 2012 | 03:38 PM
D16SiHatch's Avatar
^yep. do a dry and then wet compression test. if the numbers in any one or more cylinder is significantly off, or the compression gets significantly higher after adding a bit of oil and retesting then it is most likely rings.
Old Feb 25, 2012 | 04:15 PM
osbunjosh's Avatar
Will do that. Thank a lot guys.
Old Feb 25, 2012 | 04:35 PM
motegicivic's Avatar
You can always rebuild the head as well, new valve seals, if that is case.
Do you see smoke at start up?
Does it smoke all the time?
Any oil staining on the back bump?
climb_on
Aug 4, 2007 07:14 PM
hondab20t
12
Oct 3, 2006 06:38 PM
blackeg
Mar 28, 2005 06:10 AM
92LudeSI
Nov 4, 2003 07:16 AM
bundy
Nov 19, 2002 09:04 PM
